Thread: Strange dark grey / black algae on my pool liner. Removal advise needed.
    Hi All,
    Near the very top of my above ground pool liner I have some dark grey / black spots of what I can only assume is algae. I have tried to remove it from the surface but it simply won't budge. Does anyone what this is and more importantly how I can get rid of it?
    Thanks
    Daz
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Strange dark grey / black algae on my pool liner. Removal advise needed.
    Sounds like something "soaked in" to the liner, or its behind the liner.
    Essential Links:
    If it's behind the liner then what product should I use to try and remove it. I could release the liner quite easily as I haven't filled the pool up for summer yet.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    What have you done so far to try to remove it? What does it feel like? Pics might help.
    Hi. I tried last summer to remove it with some bleach but it didn't budge it. It feels like it's part of the vinyl like a stain. I haven't tried opening up the liner and attacking it from behind yet. I'll try and post a pic when I get home tonight.
