Thread: Clogged Vacuum Line
    May 2014
    Las Vegas NV
    45
    Clogged Vacuum Line
    I have a clogged vacuum line and have a couple questions about un-clogging the line.
    1. Is the Peterson Canvas HydroFlush any better than the Drain King?
    2. How long can it take for hydro-flushing take to work?
    3. I read if you try flushing from the pool to pump to turn on the pump to provide suction. It that safe?
    4. Is it possible the clog is at a valve and can be resolved by taking the valve apart?
    As always any help appreciated!
    Thanks in advance
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,656
    Re: Clogged Vacuum Line
    You should have a basket in the pump that should catch the stuff BUT there is always the possibility some of it could get past the basket. In that case you will have to take the pump end off and clean up the impeller. I have had to do a couple of times and it is no big deal.
    Kim
