Thread: Polaris questions - storing and SLAMing
    Feb 2015
    North Alabama
    58
    Is it ok to use my Polaris while SLAMing at a FC level of 12-14? I thought it might help to distribute any organics in the water...but I don't want to risk damaging the unit.
    And during normal water conditions...can I just keep it in the water all the time? Or is it best to remove from the pool when it's not running?
    Thank you in advance.
    saltwater generator - Hayward turbo cell
    Whisperflo multiport valve sand filter
    25,000 gallon vinyl pool (20x40 rectangular)
    Polaris 280
    TF-100 test kit
    Apr 2013
    Sacramento, CA
    2,769
    Re: Polaris questions - storing and SLAMing
    Mine has been in the pool almost constantly for three years its fine.
    Oct 2015
    Katy/Texas
    411
    Mine stays in the pool all the time. The debris bags color has bleached out, but stills works great. I have 3 bags that I rotate.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
