Thread: Couple green algea spots
    Mar 2016
    Marrietta Ga
    82
    My water is clear and all Chemicals are what is recommended here.chlorine is 5 and no CC..
    But I have seen 2 small ( 4" ) places that concerns me..I brushed them and it took some scrubbing to get it off..Should I shock it or leave it alone, we are having a bad pollen year so far and this is the first time I haven't watch it turn green over night
    On a few side notes I did add Borax and do add a 60% algae treatment every week, just 4oz maint dose.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Couple green algea spots
    I'd just raise the FC a couple points. Maybe take it from 5 to 10 tonight and give it a good brushing again tomorrow. If you spot problems and deal with them quickly, it goes a lot faster. Nip it on the bud!
    Mar 2016
    Marrietta Ga
    82
    Thanks, the water is clear so they show up pretty easily..I will shock it and see it they come back. I have read some post about using liquid bleach vs shock powder, what works best?
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by markayash View Post
    Once the powder dissolves, the pool doesn't know where the FC came from. Do you have room to add more Calcium or Cyanuric Acid? If not, the just use bleach. Pool School - How to Chlorinate Your Pool
    Mar 2016
    Marrietta Ga
    82
    CYA is pretty high at 50 ( learned how bad those test strips are, kept showing zero ) but I have room for calcium, it's around 300.
