Results 1 to 16 of 16
Thread: Hayward S-240 sand filter
    Hi,
    I am buying a used Hayward S-240 High Rate sand filter which holds 300 lbs of sand. The owner originally had a 240v 2HP motor on it for a 22x50 swimming pool.
    I am connecting it to a 110v 1.5HP motor for a 20x40 pool. Is this motor sufficient? I have read that it is important that the pump and filter be a good match.
    Thanks for any insight.
    Tony
    Re: Hayward S-240 sand filter
    Welcome to TFP!
    Yes, that pump should be just fine. The worst mistake is to have a pump that is too large for the filter. Having a pump that is smaller is fine unless it is way smaller.
    30,419
    Hey, Tony,
    Welcome to the forum. Confirming what Jason said, your filter and pump sound about right for that pool.
    The previous owner had too much pool and too much pump for that filter.
    Thanks for the quick response, guys! Great site- lots of useful info.
    I am buying this filter for about $50. Its 10+ years old. Is it worth it? What usually breaks down on these filters when they start to age?
    Tony
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    The biggest issue I see with the S-240 is cracks in the top half of the housing. Once that's shot, it's not worth replacing (costs almost as much as a new filter). Check for any hairline fractures, particularly around and connections (dome threads, bolt holes, etc.).
    Mar 2009
    Manitoba, Canada
    19
    What are the effects of this? I have a 19" filter with 200 lbs of sand and I think my pump is 1 hp.
    21 foot AG 10,000 gallon, Waterway pump and Waterway Carefree 19" sand filter
    A couple of different things happen, depending on just how much too large the pump is (yours isn't too bad).
    First, at higher flow rates the filter doesn't filter nearly as well. The higher pressure and flow rate pushes more debris right through the sand. Then, over time, the high flow rates will cause the sand to become channelized. That means that much of the water flows through holes in the sand, typically the size of drinking straws, and doesn't interact with the sand at all. Since a little of the water is still going through the sand, the filter still filters a little, but not nearly as well as it did originally. And finally, running filters at flow rates above their design flow rate results in lots of extra resistance to flow, which reduces the efficiency of your entire system, meaning higher electrical bills.
    Anyone know where I can find a manual for the S-240 online?
    I found the S-200 on haywards site, but not the S-240.
    Also, what do the 'inches' rating mean on sand filters? For example a 24" sand filter versus a 30" sand filter?
    Tony
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by tonyf666
    It's the diameter of the housing, which is pretty well the filter area.
    Guest
    Not to confuse you but there are uprated and full rated pumps. If the original pump was an uprated 2 hp (and I suspect it was) it would be exactly the same total brake HP as a 1.5 hp full rated pump so your pump choice might be exactly the same or just one step down, depending on if yours is uprated 1.5 hp (same as a 1 hp full rated) or a a full rated on. It's a numbers game that pump manufacturers play to increase sales and confuse consumers.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Tony,
    I also had a hard time finding the owner's guide, so I sent a email thur Haywardnet.com and they mailed one to me.
    If you have no luck, I would be happy to email a copy to you. Send a PM to me with your email address if you want it.
    p.s. I absolutely love my circa 1992 S-240 sand filter! It is a workhorse and I hope that by bragging on it, I don't make it sick. :P
    ETA: corect link name
    You're done SLAMing when:
    Hi-
    Since we're on the topic of pumps...
    I was given this 220v 2HP Hayward superpump, but I can only use a 110v pump. The guy told me it "can easily be changed to 110volts by movining 2 wires and changing the plug"
    Does anyone know if this is true? What would the effective HP be after downgrading it to 110v?
    Thanks
    Tony
    Yes, it can be setup for use on a 115 volt line, but you are going to need a 30 amp circuit with appropriately sized wires. There should be a plate on the motor showing how to set the jumpers for the correct voltage.
    Can someone tell me the recommended size sand filter for my pool?
    I have a 20x40 inground pool (roughly 35,000 gals). I have a 1.5 HP Hayward pump. Im trying to decide which size sand filter I need while looking at the Hayward pro series choices.
    20" – 200 lbs.
    24" – 300 lbs.
    30" – 500 lbs.
    36" – 700 lbs.
    Tony
    I would go for the 300 lb filter at the minimum, but the 500 lb filter would be better. Larger filters mean less frequent backwashing and more efficient operation.
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Quote Originally Posted by spishex
    I have the same filter and we have water dribbling out from underneath the dome. We changed the o-ring but water is still leaking. I did notice some hairline cracks on the dome threads. Do you know if there's anyway to seal them (even if only temporary), perhaps with a silicone caulk?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
