Thread: Lowering Water Level - Plumbing
    Apr 2016
    Waynesboro, PA
    18
    I'm switching over to hard plumbing this season, and am wondering if others have solved this before me. Usually, after rain I've lowered the water level back down using a submersible cover pump and hose. In my area, we received lots of rain last year resulting in me dragging out the hose, extension cord, and pump several times. Now for the question: I have a Hayward Power-FLO LX into a Hayward EC40 DE, and am wondering if others have installed a way to pump off excess water via a return line and how they did it. It'd be nice after a rain if I could use the pump to quickly lower the water level. Thanks in advance.
    24' Doughboy Autumn Breeze AG - Hayward Power-Flo LX 1hp - Hayward EC40C90 Perflex DE
    ColorQ Pro7 & TF 100
    Apr 2013
    Sacramento, CA
    2,769
    Re: Lowering Water Level - Plumbing
    With an AG its simple. On the return line just before it enter the pool install at T off to a hose bib. When you want to drain open the hose bib. That will drain down to the return without the pump. If you want to drain more you probably need to use your current method. I am assuming you have no bottom drain.
    Jul 2015
    Central Valley CA
    1,108
    Not sure about the idea of using the return as a way of pulling water out. I would be worried about what would happen if the level goes to low and the pump runs dry. How about a submersible pump and a float switch like this one?
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2016
    Waynesboro, PA
    18
    Quote Originally Posted by gwegan View Post
    Assumption correct, no bottom drain. And the EC40 Perflex doesn't have a multi-port valve. I like the your idea of the system not being reliant on the filter pump, safer to drain the pool with the pump off. Thanks!
    Quote Originally Posted by atttech-2 View Post
    Good point, a simple task of lowering the water level could result in a costly mistake if left unattended. I'd be interested to see some pictures if anyone has one of these float valves setup for this purpose. Thanks attech-2!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Is there some reason you can't just hook up the vacuum and use the hose as a siphon? A 1" hose can move some serious water even without anything more than atmospheric pressure on it.
    Apr 2016
    Waynesboro, PA
    18
    I had siphoned with a garden hose, didn't think to try a vacuum hose. Thanks for the suggestion...
    • If the pool water level is above-ground you can use your vacuum as a siphon. To do this, simply, hook up your vacuum with the pump running and the vacuum in the water, disconnect the vacuum hose at the skimmer, hold your hand over the end while it is under the water, pull that end rapidly over the the edge of the pool below the water line and let go. The siphon will start. This is the best way to vacuum, but, it can only be done on an above ground pool. Understand the moves before you try them. It works well.
