Thread: Alge in hoses & pump
    Sep 2015
    Friendswood Tx
    17
    I've drained and scrubbed the pool after algae took over over the winter. The water is clear ( no chemicals yet) and is still filling. However, I just noticed algae is in the hoses and pump. Do I need to clean these with bleach solution before running the pump? If algae is in the hoses or pump, will my new water start the whole algae over?
    Thanks!
    ashleyc - Intex 15'x48" circle AG /5,300 gal / Cartridge B / Intex 633T Filter Pump / Test Kit TF-100 / Set up (2nd time) 4/16/16
    30,427
    Re: Alge in hoses & pump
    No. You can kill the algae with chlorine but you want to get some in your pool right away. read "The ABC's of Pool Water Chemistry" up in Pool School......it's a good place to begin.
    Jun 2014
    15,198
    Hello Ashley. Of course Dave is right. But you might also consider brushing-up now on the SLAM link below in my sig..... just in case you need it. With algae already in the some of the lines, it may very-well try to make a home in that new body of water. The sooner you can hit HEB or Wal-Mart for a few gallons of bleach the better. The generic Bravo or Great Value work just fine. Stick close to the other two links below (Recommended Levels and Chlorine/CYA Chart) since those tell you exactly what you need. Best of luck today.
    Sep 2015
    Friendswood Tx
    17
    Thanks. From what I've gathered on your site, I should (1) get my PH correct. Wait 30 minutes. (2) Add stabilizer to be about 30 (with an end goal of 50). Wait 2 hours and then (3) begin adding the bleach. All this time the pump is running. Is this correct?
    We put the pool up in July last summer and had to drain it 3 times b/c of CYA getting over 100. I relied on the pool supply company - I do NOT want to go back there again!
    Sep 2013
    Charleston, SC
    538
    Ashley,
    That is correct. Great job.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
