Thread: Chlorine drop test...turns milky not clear?
    inciter's Avatar
    Mar 2016
    Alpine Ca. San Diego
    7
    Yesterday I tried the ft100 test kit..
    When I performed the chlorine drop test in the speedstir the sample turned pink, the r-0871 would remove the pink, but the sample was not clear but a milky white color.
    Regular pool not salt water,
    I did attempt a search first but found nothing...
    Thank you
    loc: San Diego (IG) (DE) 12000 Gallons (Knowledge: first time new Owner)
    Pentair 011018 IntelliFlo Variable / Pentair FILTER FNS-48
    TF100 & Speedstir
    Donldson's Avatar
    NW Ohio
    2,926
    Re: Chlorine drop test...turns milky not clear?
    Not too unusual and nothing to worry about. When the pink is gone the test is done.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    inciter's Avatar
    Mar 2016
    7
    Thank you very much.
    TF100 & Speedstir
    JoyfulNoise's Avatar
    May 2015
    13,265
    The milky look is caused by calcium hardness and is inconsequential to the results. What's your CH?
    Matt
