Thread: "Don't bleach out the liner...
    Mar 2010
    Spanish Fort, AL
    6
    ...like the last one". That's what the wife told me. The last liner only lasted a little over 5 years. Unlike my previous pool which required very minimal maintenance and spoiled me. This pool has a very narrow balance point it seems.
    I'm not sure exactly which bone headed thing I did, but I did something that bleached the liner, and at the end of its life was brittle along the entire bottom. However, the sides/walls where supple like the day it was installed. First question, what could I have done? Would this be a result of too much bleach/chlorine? Ph being too low? (I've never had problems with pH being too high)
    For the past 2 or 3 years I've used 8.25% bleach to maintain chlorine levels. I had a problem with mustard algae a year or so ago, and I followed SLAM. Actually, I think I used SLAM opening last year also.
    Spanish Fort, AL, 24k gallons, sand filter, and new Rainbow 320 chlorinator and liner April 2016
    May 2014
    Cookeville,TN
    97
    Re: "Don't bleach out the liner...
    Very important... Did you always test and retest and retest in order to be confident of your CYA level before starting a SLAM? I think I've also read on here that a an actual pool CYA level under 30 , will not test accurately. If this is true, I'd be skeptical of any CYA result at or below 30. I always add stabilizer until I get a reading of at least 35 just to make me feel more confident about the test result, and I keep testing until I get the same result at least a couple times in a row, because knowing the true CYA is so critical to managing the TFP way.
    7600 gallon; 18'X54" round; vinyl; sand filter and 110V pump, 2-speed.
    Near Cookeville, TN--1/2-way between Nashville--Knoxville along I-40; Highland Rim part of the Appalachian Plateau (we call the Cumberland Plateau for the southern half of this geological region).
    May 2014
    Cookeville,TN
    97
    The other key is that you must always test FC the way it's spelled out in SLAM instructions, and it must be an unexpired FAS-DPD kit.
    As for liquid chlorine, including 8.25% bleach, I'd say but don't know, because it's liquid and much less concentrated than trichlor, dichlor, or Cal-hypo, that it would both mix and dilute much better and far less likely to drop to the floor in high concentrations, although, I think dichlor dissolves very quickly if I remember correctly.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,106
    The majority of the time brittle liners point back to a low pH level. What pH did you maintain the pool at the majority of the time??
