Thread: Main drain cover help
    Apr 2016
    Santa Fe, NM
    2
    Hi all,
    Hoping to get some help with a main drain cover for my new to me swimming pool.
    What kind of cover should be installed here? I don't see any attachment anchors.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Main drain cover help
    Is the pool empty now?
    If so, then you might be able to install this: http://www.waterwayplastics.com/manu...-0256.0310.pdf
    Apr 2016
    Santa Fe, NM
    2
    Yes the pool is empty. Thanks for that suggestion.
