Thread: Sand
    Jul 2015
    Aiken SC
    33
    Sand
    Got my new sand filter/motor from Intex up. First had to visit Lowes to add extensions to use the old water tubes plus the new ones. It really wasn't a problem. Only wish Intex would send you longer hoses to get to the pool. Anyway, last year when I was searching for a good sand filter, I found one, but asked someone from Amazon how much sand should I order. They told me 1 bag would be enough. I ordered two bags just to be on the safe side, and guess what, the tank holds 122lbs, so I'm short 22lbs to reach the min line. I order the bags from Amazon, and need to order another one. My question to the pro's out there, is, do I need to add the SAME sand or can I go down to my local pool store and pick up one of their bags. The sand I currently have inside the tank is called Pool Filter Sand #20 Grade Silica Sand - 50 lbs. pool sand.jpg.
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Sand
    You can mix brands, as long as it is filter sand. That being said... My findings on how not all sand is created equal has some interesting pictures.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Sand
    You don't even need to go to the pool $tore. Most Lowes and Home Depot stores carry #20 Grade Silica Sand in outside garden.
    Support the site
    Jul 2015
    Aiken SC
    33
    Re: Sand
    I got done reading about "not all sand is equal" and wondering what is the best type of sand (from Lowes or Home Depot) for my type of filter?
