Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: When to open above ground pool in Illinois
    Aug 2015
    Teutpolis, IL
    45
    Just came back from vacation in Florida and brought some warm weather back with me so anxious to get the ugly winter cover off my pool that has alage blooms growing on it. I know the pool wasn't closed properly so will take some work so anxious to get started but know swimming weather in IL is still quite a ways off. Currently have the sump pump working on removing the water off the cover.
    When is it suggested to get the winter cover off and start opening the pool? I checked the water as cover has a hole and dipped thermometer in and it read the water underneath at 52 degrees.
    I know I want to start before water hits 65 degrees if i recall because of algae. This is our first year opening the pool as just bought the house in August last year.
    thanks so much!
    Jun 2014
    14,989
    Re: When to open above ground pool in Illinois
    60 degrees is typically our magic number. But I believe some others in your area have already opened. Weird season. Your call really. Weather permitting, the earlier the better usually. But make sure that when you do open, it's at a time when you can invests the babysitting required to SLAM if needed.
    klynch494's Avatar
    Aug 2015
    Twin Cities/MN
    96
    Here in Minnesota, my water was 62 degrees this afternoon upon removing my solar cover to do the weekly brush and vacuum. After stirring the water around it dropped to 58.
    ~Kevin (MN)
    13.5k gal, 24' Round AG Vinyl
    2HP Waterway Pump, 200sqft Hayward Element Filter
    BBB Method & AuquaSmarte Inline Chlorinator, TF-100 Test Kit
    Kevin, TFP Believer & Supporter
    (Yup, I drank the pool water)
    13.5K gal, 24' Round AG Vinyl, TF-100 Test Kit
    2HP Waterway Pump, 200 SqFt Hayward Element Filter
    Recommendations: Pool School, TFTestkits & Pool Math
    Aug 2014
    Northern IL
    4,615
    I am in Northern IL and I usually aim for April 15, an easy date to remember.... Taxes! Yikes! I normally don't swim until Memorial Day, but I open clear and chemically balanced, and then I can just keep it that way with minimal effort. Best wishes!
    May 2014
    Clarksburg, WV
    331
    I think i'm going to uncover mine today. Supposed to rain Thursday and Friday. Hoping the rain will fill it up some. Then be in the high 70s here for a few days and sunny.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    We're in Chicago(-ish) and opened it this past weekend. I think we've finally made it past sub-freezing temps.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Snap96's Avatar
    Jun 2015
    Chicago, IL
    39
    We're in the NW burbs of Chicago and open next week. We had the pool installed last year and our contractor recommended open early...close late.
    Barrier Reef Whitsunday 35' IG Fiberglass...17,500 gallons...Hayward H250 Heater...Hayward Max-Flo XL 1.5hp Pump...Hayward 24" Pro Sand Filter...Hayward Aqua Plus SWG...Taylor K-2006 and K-1004 Test Kits...Built Spring 2015...Use village well as fill water
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    My cover is still on pending a tree removal, but if you do have to SLAM the cooler water temps are your friend. Look at all these IL/Chicago-ish pools!
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Aug 2014
    Northern IL
    4,615
    Yay! St. Charles here.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    I wait for the helicopter seeds from Maple trees to stop.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jul 2012
    Chicago, IL
    356
    I usually target no later than Memorial Day though was later than that last year as I had to replace my liner. Added heat last July so will most definitely be opening by early May. I need to re-stain my deck first though...
    Pool Tool - same heater and also a Packer fan living in Chicago! (I grew up here my whole life, but my Dad was born a few blocks from Lambeau so I got raised a certain way.)
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Quote Originally Posted by Pauls234 View Post
    MEMORIAL DAY??? And you call yourself a lifelong Chicagoan? That's like giving up 25% of the usable pool season. Given the sizable cost of my pool-owning life, Mid-April to Mid-October is my pool season.
    Geebot
    Chicago, IL
    Pool Tool's Avatar
    May 2014
    757
    I'm out in Sycamore, so not too far from you Marian. Paul - sounds like you were raised right! Though I am glad i live outside the city, that would make it more difficult. Another Paul, ps0303, inspired my avatar. He was Chicago relocate and added his Bear avatar...
    I know I was almost banished last Saturday when the cover was still on and the temps hit 80.
    Aug 2014
    Northern IL
    4,615
    I hope to open this coming weekend. We are a week late, but the lawn mower was broken and that took priority. With the warm temps this weekend, I was nervous so I opened the auto-cover and it looked perfect (except for some leaves and worms...)
    Pauls234: Waiting until Memorial Day? Don't you open green??? That's late! Must be the same twisted thinking that makes you a Packer fan.... Hahaha!
    Jul 2012
    Chicago, IL
    356
    You guys are on to something.... as I think back, I guess it was early to mid-May the last few years. But now that I have heat, it will be sooner. I am liking the sound of this weekend actually, you guys are inspiring me.
    Marian - I've never opened green thanks to TFP!
    Aug 2014
    Northern IL
    4,615
    Go for it!!
    Aug 2015
    Teutpolis, IL
    45
    Thanks everyone. Above ground with no heat and water is currently 50degrees but it was clear when I took the tarp off!!! Was expecting the worse but clear with lots of earthworms. Hoping the rain tomorrow will help fill it and hopefully fix the filter (that we accidentally messed up).
    18x33x4 oval Above ground pool- 15300 gallons, sand filter, full sun no shade
    tft-100 test kit
    Central Illinois
    Aug 2014
    Northern IL
    4,615
    Good luck with the filter. Gotta love the chemical-free refill from the rain!!!
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    Northwest Indiana here opened last weekend, water is 66 degrees.
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
  20. Back To Top    #20
    Aug 2014
    Northern IL
    4,615
    Wow! Alert to all in our climate area. Get open!!!
