Results 1 to 8 of 8
Thread: AA treatment has turned my pool brown
    Apr 2016
    New York
    5
    So I have had some metal staining last year. Tested via vit c tablet and it cleared right up.
    The pool is topped off via a well that has iron and iron bacteria. I try to avoid it but sometimes there is no other choice.
    Opened the pool early last week. Got chlorine down to 0 and added 4lbs AA. Stains at the shallow end were gone. Some remained at the deepend.
    Left the chlorine Gen off due to cold water [50c] added Jacks purple stuff and some kemtek algecide.
    Returned to check the pool this weekend. Stains had faded at the deepend but returned at shallow. So I added another 4lbs of AA and the pool has turned brown before my eyes. The water itself appear clear at least by the glassfull
    Chlorine is still 0 (no chlorine source) but PH has dropped to 6.8 expected due to all the AA but it seemingly had the opposite effect on the staining this time (it kind of lighted a bit in places first. It over the course of not even 2 hrs the whole pool is brown)
    Any help or advice great fully received as I am at a complete loss for how to proceed
    Thanks
    2006 install. In ground. SWG
    30 x 12 vinyl pool approx 18000 gallons
    Apr 2016
    New York
    5
    Re: AA treatment has turned my pool brown
    Well I may have answered myself.
    I decided to take a look at the filter. As my local pool store had just opened my pool I assumed that it was pretty clean. Full of green gunk. Got a good idea where my iron source is now. And of course adding AA is striping it straight out of the filter back into my pool. Doh!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    If the stuff has precipitated, you're sort of lucky.
    I did a little search on the subject from last season. Look at pictures in these threads and see if you don't get inspired. If you do, do what they did.
    A Tale of Two Filters... and Ugly, Rusty Water.
    Just got Taylor-2006 Test Kit. Want to verify what I should add.
    Results of first TF-100 test ran on fill water - Page 2
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Yeah, good that it precipitated out and moved to the filter. Now you can clean the filter and get rid of it.
    Apr 2016
    New York
    5
    Yes apart from the fact I washed so much of it back into the pool . The paper towel method sure looks interesting
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    There have been some posters who have used fiber batting (such as you'd use to stuff a doll or pillow) and homemade filters with good results.
    Aug 2014
    Northern IL
    4,615
    What type of filter do you have?
    Apr 2016
    New York
    5
    Sta rite cartridge
