Thread: Can't Identify Return Line
    Jun 2014
    Round Rock/Texas
    5
    I have an older inground pool with spa and inground cleaning system. I am drawing up a diagram for future reference and have identified everything except one return line.
    I have five return lines. They are
    1. Spa Return
    2. Cleaner return
    3. Spa Water Feature
    4. Skimmer Return
    5. ????????
    cant identify what number 5. is. Need help!!
    I have an inground pool that is approximately 30 feet by 40 feet in an irregular shape with water fall on one side. Approximately 25k gallons. Gunnite. Has inground cleaning system that is 20 years old and not working. Modification was done at the venturi type skimmer to use a Polaris 360. Pecan trees all over pool so inground cleaner is not feasible even if it was working.
    Jun 2014
    15,178
    Re: Can't Identify Return Line
    Can you post a pic? Main drain?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,025
    Look around the pool for any mystery ports without a standard eyeball. There may have been a pressure side cleaner at one time.
    Or it could be a line to discharge excess water, especially if you have a cartridge type filter.
    Ultimately, you may just have to close everything but the unknown valve and turn on the pump and watch the pressure gauge. If it skyrockets, the unknown port is capped. If it stays normal or goes up some but there's plenty of flow in the pump basket and the skimmers, you just have to watch for water movement somewhere. And also watch the water level, if the return flow isn't obvious. You could be emptying the pool.
