Results 1 to 7 of 7
Thread: Hayward CL220 fittings needed
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    I have a CL220 inline chlorinate that I only use when I am away on vacation. I normally just use liquid bleach, but need the automatic chlorinator to prevent algae when I am away.
    I need some replacement parts for the chlorinator and want to get the pool opened and pump running without it. To block off one of the fittings in the pipe, I usually just take one of the CLX220H compression nuts, use a 6" section of tubing in it folded over and ty-wrapped closed. Do they make a compression nut fitting that has no hole in it, just to cap off the line?
    In this picture, i want to replace the compression nut and hose with just a cap.
    Thanks in advance,
    James
    28K gallon, raised beam, plaster/ceramic color quartz with attached spa. TF-100 test kit
    Hayward 1.5HP super pump, DE4800 DE filter, Hayward inline chlorinator w/3" tabs (off)
    Pool: 2 floor drains, 2 skimmers, 3 floor returns, 2 wall returns, 3.5' deep > 8' deep
    Spa: 2 floor drains, 4 jet returns
    Jun 2014
    15,008
    Re: Hayward CL220 fittings needed
    Hi James. Not sure if you found a remedy for this one yet, but I found the following thread that shows a pic in post #6 that may help you temporarily: Removing Hayward Offline Chlorinator - plugging holes. Hope it helps. Good luck!
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Thanks Pat, yea...I guess that would work even though I d not believe the plastic thread is 1/4 NPT. Enough t-tape would make it seal. It is only temporary, so it shouldn't hurt.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Is there any reason you can't just cut a chunk of neoprene gasket material to stuff in that cap and screw it on tight? Shop Plumb Pak 6-in Rubber Washer at Lowes.com
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    No, the caps have an integrated ferrule in them, there is no room to stuff any sort of gasket inside. Thanks though.
    Apr 2015
    South Central PA
    297
    I'm putting a Stenner in, so I needed to block off my auto chlorinator tap. I bought a brass cap at Lowe's, used some teflon tape...it's held with no leaking (make sure to use the tape though or it will drip)
    Edit: I went back and read some posts- I did what Texas Splash linked to in a post above.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    JamesR's Avatar
    May 2015
    Nazareth/PA
    74
    Great to know the brass cap worked. Thanks guys...
