Results 1 to 18 of 18
Thread: Starting up pool
    Starting up pool
    I just took the cover off my in ground pool and it is a swamp. This is the first time it's been this bad because normally I have it open before it gets this bad but due to a unusual cold spell it delayed me opening it. It is 27k gallon vinyle pool, so far I put 6 one pound bags of hth shock in the pool last night, today the pool is still a blue green color, what should I next???
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Starting up pool
    Quote Originally Posted by bhuels View Post
    First, stop using "Shock" unless you a) know what it is precisely and b) need the additional ingredients. Dichlor and Trichlor are both very acidic and also add CYA. What's the pH? What's the TA? What's the CYA level? If CYA is already high or pH is low, you're just making a bad situation worse. If the "shock" is Cal-hypo, do you need the additional Calcium? Actually, with a vinyl liner, the answer is no. But if CH is already high, then again you're just making a bad situation worse. High CH can cause scale on the walls.
    We have explicit instructions on Turning Your Green Swamp Back into a Sparkling Oasis
    The way to do it is what we call the SLAM process. Shock Level And Maintain. A one-time blast of chlorine doesn't fix it, as you've discovered.
    Scroll through some of the links in this thread and look at the pictures. If you find one that resembles yours, do what they did to clean it up.
    Lastly, please fill out your Signature. Three years is long enough without one.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Welcome to the forum. You're gonna need a good test kit as we recommend in Pool School. We'll walk you through it.
    Ok I will add more information
    Aug 2014
    Northern IL
    4,615
    How about some current test numbers then?
    27k gallon In ground, vinyle, Hayward aqua rite swg turbo cell15, Taylor K-2006 test kit,Hayward heater, Hayward dex2421 DE filter, Ecco pool pump 2 HP single speed
    ta 100 cya 0
    Aug 2014
    Northern IL
    4,615
    Because you have 0 CYA and 0 FC, you probably should get some liquid chlorine or bleach and try the test outlined in post 7 of this thread: CYA to Ammonia
    I have added 3 1 gallon bottles of shock to the pool, and also some muratic acid for the ph, the pool was green yesterday when I opened it and now today as you can see is just cloudy, have been having to backwash DE filter every hour or so because it keeps clogging up, will be adding cya to it next
    Question?? Can I run my pump without putting DE in it because right now I'm having to backwash Atleast every hour?? Will it hurt to not use De until it clears out more, and also can I use clarifier to help with the cloudyness??
    Aug 2014
    Northern IL
    4,615
    Clarifier is not recommended in your situation. Before you add CYA, check your FC to make sure you don't have ammonia as in the prior link. Just my thoughts.
    edit: saw in your Signature that you have a DE filter. Can't answer that one.
    Jun 2014
    14,970
    Not a good idea without DE. Here are a couple manual quotes:
    "Never operate filter in excess of three (3) minutes without use of diatomaceous earth. Diatomaceous earth is the substance that filters the water, the filter cloth merely supports the diatomaceous earth. Operating without diatomaceous earth will damage filter elements and shorten filtering cycles."
    "To avoid damages to the grid elements, DO NOT operate the filter for more than a minute or two without the D.E. pre-coat."
    You can check your manual to confirm, but I imagine it will say something close to that.
    Ok, I didn't know just thought it would keep me from having to backwash and lose so much de every hour lol
    How do you check for ammonia??
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    See the link in post 8 from Marian Paroo.
    Essential Links:
    Update on the pool!! Currently is crystal clear and chemicals are nice and balanced, still getting the salt level up but pool is so much better than it was 3 days ago!!
    Apr 2010
    East Texas
    9,556
    Have you passed all 3 criteria for the SLAM process yet?
    Yup, I slammed it hard
    Aug 2014
    Northern IL
    4,615
