Another good day, just too much Pollen taking up my time skimming, clogging my skimmer basket, consuming my FC. FC consumption varied more than I thought, so I encourage anyone doing their own slam and is reading this to really be sure to test at minimum 3 times a day when you can. If you have a really bad pool you really do want the XL option OR to at least get the big bottle/an extra of R-0871 testing chemical because each time you test your FC during a SLAM you will use at least 2 drops times your shock level (for example, if you have a traditional pool with CYA 30 your shock FC level is 12, thus if you're like me you are really trying to keep it no lower than 12.5 and no higher than 15 because you would prefer to not bleach your liner white with absurdly high FC. So even if you only test three times per day, you're using a minimum of 75 drops of R-0871 per day for between one and two weeks, or 500-1000 drops total for the SLAM of a badly neglected pool. I only do the CC test occasionally when curious until the water is crystal clear since knowing my CC doesn't change anything - I still have to keep FC at shock until crystal clear water and OCLT are both passed, then I can see if my CC are gone, but until then, it doesn't really have consequence.
I did have to add PH 8.2 hose water after a back wash today, so I doubt I'm still at 7.2. I think if I ever do another nasty pool slam I'll get the chemistry to do ph on shock water.
Happy Mother's Day to all those who have brought a life into this world or who have lovingly nurtured, supported, or impacted the lives of others in a maternal way. You are all amazing.
