Thread: Adjusting Ph
    Apr 2016
    Dothan
    9
    Question Adjusting Ph
    I Have a new pool no test kit yet (Friday) however pinch a penny tested my water 3 separate times and I have made some adjustments my question is this should I try to adjust everything at once or just one item at a time my plan is to bring up the ph with 20 mule team borax by 1/2 the recommended amount so I don't overshoot ( already did that with muratic acid was 8 now 6.8 also add 80 lbs of salt at the same time 3000 ppm ^ to 4000 ppm per tfp recommendations am I trying to do to much at one time or should I work one item at a time?
    ttl clh*
    free clh 5.0ppm
    cc *
    ph 6.8ppm
    acid *
    base 4
    ttl alkalinity 70ppm
    stabilizer 10ppm
    ttl dissolved solids *
    salt 3000
    S/W/G Intellichlor IC 40 29k Vinyl I/G 18x36 Rectangle Hayward S 244 T filter Pentair Superflo 1.25 h/p pump Polaris TR35P Cleaner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Adjusting Ph
    Welcome to TFP
    You are on it, Your FC is a little high and will get used fast because of no CYA.. I would bring your ph up to 7.2 and then just stay where you are at until you get your test kit.. You (and us) will now much better what is going on then..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Adjusting Ph
    Welcome to TFP!
    Congrats on the new pool! Start here, Pool School - ABCs of Pool Water Chemistry
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Adjusting Ph
    Welcome!
    In case you haven't read enough here to know... we don't trust pool store results. Until you get your own test kit and your own test results, your best plan of action is to adjust pH and keep FC above 3. Except it's kind of hard to measure pH and FC without a test kit... You see how you're stuck in a loop.
    Once you have a kit in your hands, all your adjustments can be done in a couple hours, and that's being generous with the time intervals between additions. So all you really want to do now is keep the pH from etching any metal parts in the pump or heater and keep enough FC to keep algae at bay. It's probably still too chilly to swim, so there's no big worries about adequate sanitation, just keep algae from starting.
