Thread: Restoring or painting yellowed plastic wall fittings in pool?
    Aug 2015
    Jacksonville, FL
    8
    Question Restoring or painting yellowed plastic wall fittings in pool?
    Hi all. I have a 23 year old saltwater gunite pool. The original embedded ABS/PVC wall fittings for the lights and return lines have yellowed over time from UV light exposure and cannot be easily replaced without tearing out the surrounding gunite. I've been reading that the discoloration is due to bromine used in manufacturing of ABS and PVC plastics reacting with sunlight over a long time. Over time the white plastic will turn yellowish brown.
    The pool is drained for maintenance right now and I was wondering if anyone has ever prepped and spray painted embedded wall fittings with Krylon "Fusion for Plastic" spray paint? This paint claims to be made specifically for plastic and that it binds at the molecular level with hard plastics such as ABS or PVC and will not chip off after 7 days cure time. This sounds like it may be a good method of restoring the fittings to a nice white appearance if the Krylon Fusion paint really works as advertised.
    Has anyone ever tried painting the plastic pool wall fittings, and does it work?
    Kevin
    My pool/spa: 14k IG, Pebble-Tec Tahoe Blue interior, Zodiac Caretaker in-floor cleaning system, Aquabot Turbo robotic cleaner, 3HP Pentair Intelliflo VS pump, Pentair Clean & Clear 200sf cartridge filter, Circupool RJ-45 SWG, TF-100 test kit, Hayward Heat Pro HP2100TCO heat pump, Fiberstars 6004 metal halide illuminator with four 150-strand fiber optic lights.
    Jul 2015
    Central Valley CA
    1,109
    Re: Restoring or painting yellowed plastic wall fittings in pool?
    I have use Krylon on yellowed plastic vinyl of an RV and it has held up in direct sun for 4 years no flaking or yellowing, no experience submerging it in water though. As good as it works if you can replace them I would, they are not all that expensive and it will be less work with assured results.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
