Thread: Simple Pool/Spa/Heater Control
    Apr 2016
    Tempe, AZ
    4
    Hi-
    I've got a fairly standard setup. Pool and spa (separate pumps and filters, no overflow) that share a single heater which I'm going to upgrade to a new one. I'm looking for a low-cost solution (other than manual) to automate the heating of pool and spa. Is there a heater that has some timing/control built-in?
    Ideally, I'd like to be able to have the heater start the pump and check the temperature of the pool and/or spa every hour or so, and if needed run the pump and heater until temperature is met outside of the regular filtering time(s).
    I'm okay if it can only do either pool or spa, so long as I can override to heat the other manually. I'd likely have the pool heated regularly spring/fall, and the spa heated regularly winter. I'm in Phoenix if that makes a difference.
    I'm trying to avoid the $1000+ automation space as it seems like overkill for my needs.
    Is there anything simple out there that can do this task? I don't need light control or anything else that the big packages offer.
    Thanks.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Simple Pool/Spa/Heater Control
    Welcome to TFP
    There are many options but I also wanted a simple controller and went with Intermatic.. they have a complete system for 800 or so.. Pool Spa Supplies | Intermatic - Ctrl, Intermatic Multi-Wave PE35065RC, ECS Plus, 80A, w/Remote - PE35065RC
    You may also be able to just get the controller (Intermatic PE653RC) like I have and then add the solar/heater/spa controller that you would need..
    Intermatic PE653RC Wireless Control System for Variable Speed and Two-Speed Pumps - Sump Pump Accessories - Amazon.com
    hope this helps
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Apr 2016
    Tempe, AZ
    4
    Thanks for the info cowboycasey.
    I'm thinking I'll just do the old manual dance for now. Any advice for what I should or should not do with the manual setup knowing my plan is to add automation at a future date? I'm going with Jandy valves and diverters so I can add actuators later. I'm getting a Raypak Digital Propane heater which should be controllable from most automation systems. Any other gotchas that I should be wary of?
    Thanks again!
    Pool: Inground 25k gallon concrete & quartz plaster, 1 1/2 HP pump, Sta-Rite Posi-Flo 135TXR
    Spa: Inground 2k gallon concrete & quartz plaster, 1 1/2 HP pump, Sta-Rite Posi-Flo 135TXR
    Heater: a broken Teledyne 50k btu
