Thread: Balancing order
    Mar 2016
    Fort Mill/SC
    41
    Balancing order
    converting to SWCG and have really high CYA (100+) So I plan on draining about 30% of the pool, which should get me closer to 70-80. So obviously that should be the first thing to balance. I have no idea how that's going to change my other readings, but will retest after that. I have salt at the ready. I noticed some things can through off other readings, so is there a decent order to follow to make it easier. i.e. adding baking soda will raise ph, etc.
    PH is already really low, so i imagine it will be even lower when i add new water...
    2010 In Ground ~ 12-15,000 Gallon estimated
    ~3 ft shallow ~ 6 ft deep ~38 ft x 17 ft Freeform shape Pebbletec Finish
    2 Drains, 2 Skimmers, Sidewall Vacuum (Not in Use)
    Dolphin Oasis Z5 - PHPF1.0 Pump - Jandy CV340 Filter
    Fort Mill, SC
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Balancing order
    It depends on the PH of your fill water. We'll have to see what it looks like. Usually, PH first, FC second
    Mar 2016
    Fort Mill/SC
    41
    Re: Balancing order
    Thanks.....again !! I will drain and fill and plan on fixing ph first.
    Fort Mill, SC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Balancing order
    Retest that CYA using the dilution method. A lot of people here have estimated they were at 120 or whatever and discovered they were closer to 200 and all the draining and waiting to refill had to be repeated. Step 9 explains how to do it.
    Mar 2016
    Fort Mill/SC
    41
    Re: Balancing order
    thanks i will again tomorrow with a bit more sunlight, tried the diluted method just now looks closer to 180, but my lighting is average in house.
    Fort Mill, SC
