Thread: Help with New Hayward pump
    Aug 2015
    Chesapeake, Virginia
    10
    I just received my new Hayward pump from Amazon, and I've discovered a problem. With my original Sta-Rite pump the connector that attached to the hose running from the pump to the Sta-Rite filter was and externally threaded peace with the hose attached to using a 2 or 2.5 inch collar (picture attached), there has been some debate at various Leslie's as to the width. Unfortunately the pump came with an internal 1.5inch hole (picture attached). I've seen adapters to correct this issue, however neither my local hardware stores (Lowes, Home WP_20160415_16_36_55_Pro.jpgWP_20160415_16_36_33_Pro.jpgDepot, and Taylors) carry anything like it, and of course Leslie's doesn't either. Does anyone know where I can get the needed adapter?
    Artesian Riverview 24 Ft Round 54" Wall Steel Pool (Dec 2008)
    Approx: 13,500 Gallons
    Sta-Rite 200lb Sand filter and 1hp Sta-Rite Pump
    Wedding Cake Steps
    Frog Chlorination system
    38,279
    Re: Help with New Hayward pump
    It is highly unlikely you will find the male portion that would go in that union fitting. Many manufacturers use proprietary threads. I think you are going to have to use a regular male PVC fitting screwed into the pump and then cut off the union on the hose and use regular PVC fittings (maybe adding a full union so you can work on the pump as needed).
    banditig's Avatar
    Sep 2015
    Ohio
    466
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Aug 2015
    10
    Thanks for the replies and the link. I think I've decided to just hard plumb the line using PVC, then I'm going to use flex PVC with shutoff valves for my filter and return.
    Wedding Cake Steps
