Thread: part of the liner is coming loose
    Aug 2008
    Las Vegas, NV
    116
    There is a small section, maybe 2 inches where the liner has come loose from the edge of the pool (in the deep end). Is there advise on how to handle this?
    Pam
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: part of the liner is coming loose
    Push it back in. If it keeps coming out, there are ways to deal with it. It will go back easier when it's hot out.
    Quote Originally Posted by JohnT
    I am just curious, because my liner is doing that in places also. What other ways are there to deal with it? It seems to be very hard to pull it up enough to tuck it back in easily.
    vinyl IG 18x36 HP pump sand filter
    It isn't usually especially easy to get it back in the track, but it can be done, especially when the weather is very warm. Once you have it back in the track you can use liner lock, or pennies, to wedge it into the track so it won't come out again.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi folks, my advice on getting a liner back into it's track is here.
    Luv& Luk
    -Ted
