Thread: How to see rpm instead of percentage on display
    WhitB08's Avatar
    Apr 2016
    Murfreesboro, TN
    18
    Good afternoon! Does anyone else have a Hayward Goldline aqua pod that can explain to me how to change the setting where I see the actual RPM instead of the percentage for the VSP? I have searched through the thread and googled as well as reading the manual and I am unable to find the answer. We bought a home with a pool and I am still trying to figure everything out. Thanks for any help!
    23400 gallon IG vinyl built 2013
    salt generator
    sand filter
    Hayward VSP with Aqua Pod
    slide, deck jets, tanning ledge with bubblers
    Jan 2014
    Buckeye AZ
    807
    Re: How to see rpm instead of percentage on display
    The only place I've been able to see the rpm is on the controller that is physically attached to the pump. Not in the prologic controller that is mounted to the service panel/wall, and not on the remote. You might just need to make a quick reference of what rpm is at different percentages.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    mas985's Avatar
    Pleasanton, CA
    11,737
    Is there any reason RPM is more important than % to you? They both have the same linear relationship to flow rate.
    Mark
    WhitB08's Avatar
    Apr 2016
    Murfreesboro, TN
    18
    Thanks Chris. I'll check there.
    Mark, i'm just trying to orient myself to the system, and every article I read speaks in terms of RPM. The pool company that installed the pool told me that it may be calibrated in a way in which 100% isn't actually full power for the pump.
    salt generator
    sand filter
    mas985's Avatar
    Pleasanton, CA
    11,737
    IMHO, % is far more meaningful because a 25% setting is 25% flow rate while you have to do the math for RPM. I just think % is easier to use.
    Mark
    Jan 2014
    Buckeye AZ
    807
    plus the pump panel that shows rpm is the only place that shows actual wattage usage, which is helpful for extrapolating out energy costs. Because pump flow % is not totally correlated to pump power usage.
