Thread: stains on pool floor and walls
    Mar 2016
    Arlington tx
    19
    We bought our house with the pool about 2 years ago. The pool hand not been maintained very well. Its a plaster pool and the plaster has some etching. I know its going to need redone in a few years. The pool floor and walls are stained with algae. I have brushed with my pool brush, but no luck getting them off. I even tried a wire brush on one spot on the wall. It helped a bit, but it didn't all come off. I had the bottom fall of my floating cholrinator and the 3 inch tablets laid on the pool floor. Where they dissolved I have nice clean circles. Is there a fix for this other than draining the pool and doing an acid wash?
    I live in Arlington TX. It is a in ground plaster pool approx 25,000 gallons. It has a Nautilus NS DE filter with a 1 1/2 hp starite pump. It has a pool cleaner brand suction style pool cleaner. TF-100 test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: stains on pool floor and walls
    The fact that the trichlor puck removed the stain indicates that it is an organic source. Normally, elevating your chlorine level close to shock level for your CYA for a couple of weeks and brushing as often as you can will clear up the stains. Chlorine CYA Chart
