Results 1 to 11 of 11
Thread: Repair crumbling spa step - pebble tech
    Apr 2016
    Oakley, CA
    5
    I have a step in my spa that had a crack in the pebble tech, which I thought was going to be a simple patch. After taking a chisel to the step, much to my dismay, part of the step came a crumbling down. The step is curved and I need to repair it before I can put new pebble tech on it. I am not sure what to use to repair it or exactly how to proceed. I have a couple of ideas, but I would really like to here some opinions before I go ahead and do something stupid. I have attached a couple of pictures to show you what I am up against.
    Any advice would be greatly appreciated.
    12,000 Gallons - IG. Pentair CCP520 cartridge. Whisperflo WFE-8 2.0 hp. Built - 2000. Leslie's Deluxe OTO Test Kit. Other - Spa, Cleaner, WF , Jandy Aqua Link RS4
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Repair crumbling spa step - pebble tech
    Welcome to TFP!
    Please add your state or country to your location in your profile so that it shows up over there <---. Climate is a very important factor influencing advice for maintaining pools. How long has the pool been drained?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Oh man! I bet your heart dropped to your toes when that happened I have not clue how to help you but wanted to know I feel your pain!
    Kim
    Apr 2016
    Oakley, CA
    5
    Quote Originally Posted by pooldv View Post
    Welcome to TFP!
    Pool is not drained. Only the spa is for about 10 days now.
    Apr 2016
    Oakley, CA
    5
    I live in Oakley, CA, which is about 30-40 miles inland of San Francisco.
    Apr 2013
    Sacramento, CA
    2,769
    Is that dirt under there?
    Ok pebble tec is a proprietary product so if you are going to match what you have you need to call a pebble tec installer to do the work. That's Aqua Gunite in Livermore or Adams Pool solutions in Pleasanton.
    It looks like your underlying gunite is only about 4 inches thick and I see no rebar. That could be a serious problem. I would need to get down and see what rebar there is and how that shell is constructed. I would like to tie to rebar. As for a cement choice any high strength concrete will work. The issue isn't really the concrete but how you tie it in.
    So I would first call one of the companies listed above and get a bid and an evaluation. You are going to need one of them to do the final finish work if you want it to match.
    Apr 2016
    Oakley, CA
    5
    Quote Originally Posted by gwegan View Post
    Thank you that is extremely helpful. I really appreciate it.
    Jan 2015
    las vegas
    92
    Happens all the time with pebble pools/spas.
    Picture doesn't show the new rebar is set with epoxy. Many trade articles written on this happening fix is fairly simple. Cost usually $500-$700
    Apr 2016
    Oakley, CA
    5
    Quote Originally Posted by lasvegaspools View Post
    Sent from my SGP561 using Tapatalk
    Thank you. That's great. A picture is definitely worth a thousand words. This site is great. I am very happy that I found it. I am feeling pretty good about this fix at this point. Thanks again.
    Jul 2015
    Central Valley CA
    1,107
    Adams primarily works the Tri Valley and South Bay you can try them but not sure they will go to Oakley. Check with Trademark in Modesto I know they have done builds in Brentwood so I wold think they will go to Oakley too.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    DFW, TX
    24,450
    Everyone has you on the right track here. Need to drill and epoxy new rebar, preferable into old rebar. Form new concrete step and replaster. Your climate isn't too hot and sunny, that is good. And it is only the spa, also good. But, spray down the pebble every day to keep it moist. A sprinkler with a hose timer is a good option.
    From Pebbletec's website, Explore Pebble Technology International (PTI) Superior Quality Pool Finishes™ Pebble Tec
    It is important to refill immediately after service/repair has been completed. Generally, this would be within a 24-hour period of draining the pool. However, if the finish is well bonded to the substrate, if the finish is frequently saturated (so that moisture is maintained within the finish) and if proper precautions are taken, the finish can withstand being drained for several days under optimum circumstances. This should only be attempted under the supervision of a PTI certified builder or authorized applicator.
