Thread: Do salt water chlorine generators soften water
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    I'm tiring of the issues with the chlorine pucks, like raising the stabilizer levels so I am considering a SWG. Do you know if SWG also soften the water? We have hard water (325+ Calcium Hardness), so that would be an added benefit if it helps with the hardness levels.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Do salt water chlorine generators soften water
    No, they don't soften the water. The water feels "softer" on the skin and eyes due to the salt, but calcium levels aren't affected.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    The SWG will not reduce your CH, but the water will have a softer feel to it with the addition of salt to the water (Don't need the swg to get the same effect, but the swg will automate the addition of sanitizer to you pool ). You can also get an addt'l softening effect from adding borates as well
    Johnl's Avatar
    May 2008
    88
    Thanks for the quick response. Love the forum. Thanks again.
    23K Gunite IG Pool
    Aquarite 40k SWG
    Polaris 360
    Guest
    Some further clarification. Water softeners soften water by using an ion exchange resin that grabs the calcium, magnesium, and other metal in the water and replacing them with sodium ions (which is why sodium chloride or salt is used to regenerate the resin.) The salt used does not, in itself, soften the water. Since SWGs obviously do not involve an ion exchange resin they do not soften the water. They produce chlorine by electrolysis of salt (electrically 'breaking' the salt into sodium and chlorine).
