Results 1 to 7 of 7
Thread: Glass firepit
    Feb 2016
    Houston
    323
    Glass firepit
    I totally want a glass firepit, but the kids want to roast marshmallows and cook hot dogs. Can this be done on a glass firepit? Will it get hot enough? Probably need to worry about dripping mess on the pretty glass.
    Might consider a wood burning one, but it will be within a few feet of our soon to be built salt water pool and not sure I want the wood/ash mess so close to the pool. Or the metal that close to it.
    My pool thread. IG 31' x 20', 3.5'/4.5'/6', 8' spa, 4T moss rock WF/WW w/jumping rock, 7' x 11' sunshelf 3 bubblers, travertine coping, spray deck, Hayward equip: SwimClear 525 Cartridge Filter, H400 natural gas heater, Tristar Dual Speed EE pump 2HP, Tristar EE pump 1.5HP for water features, blower 2HP, Prologic P/S 8 w/aqua pod remote, Aqua Rite T-15 Salt System, Tigershark QC robot, networked Colorlogic LEDs 2 pool 1 spa.
    Jul 2015
    Central Valley CA
    1,107
    Re: Glass firepit
    A compromise might be a gas pit with ceramic logs and lava rock, the ceramic gives the pit some mass to absorb the heat and radiate it out. Does not get as hot as wood but plenty of heat for a smore. You want to avoid dropping things in but won't kill it if you do and eventually it will burn off. If it ever got real bad you can clean the logs with a wire brush and some MA the lava rock can just be replaced. I had a pit at my previous home for years and never had to replace the rock and we never cleaned the logs the thin layer of soot they get gave them a realistic look.
    You can ofcourse use fire glass instead of lava rock but it can be expensive and as you eluded to might be painfull if it gets marshmallow goo on it.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Feb 2016
    Houston
    323
    Re: Glass firepit
    Thank you. I'll take a look at ceramic logs and lava rock ones.
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: Glass firepit
    We have a glass fire pit and roast smores all the time. No worries with marshmallows, they just burn off. Never tried hotdogs though.
    Matt
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,411
    Re: Glass firepit
    I was thinking the goo would burn off. IF it get bad I bet you could scoop up the ones that had goo onthem and let them soak then rinse them off.
    Glass is SO pretty (bling). I would give it a go!
    Kim
    Feb 2016
    Houston
    323
    Re: Glass firepit
    Oh yay, thanks Matt ad Kim we may just give it a go then.
    May 2015
    13,176
    Re: Glass firepit
    I ordered ours from American Specialty Glass. 3" of 1/2" lava rock topped with 3" of 1" colored glass chunks. Their website has a calculator on it to help determine how much glass you need for a given size pit.
    Matt
