Thread: Pool resurfacing / SWG upgrade
    Jul 2009
    Massachusetts
    188
    Hi, we decided it's time to resurface our 16 yr old pool - we are the 3rd owners. I don't believe it's ever been resurfaced and is actually in good shape, no cracks but really stained. I tried to acid wash it myself, but that was a bit of an anxiety-ridden disaster so I decided to spend the $ and hopefully not worry about it 20 yrs.
    I got several quotes ranging from $12600 for Pebbletec, 16400 for Pebblesheen and 11K for Satin Matrix Wet Edge (pool is 21 x 35; 95 linear feet, 3.5 ft to 8ft - kidney bean shaped)
    My first question is whether it's worth the extra cost for Pebbletec. My understanding is that in my area (Massachusetts), there is only one pebbletec applicator, which causes the pricing to be substantially higher than Wet Edge. But I've been told that as an applicator, the Wet Edge guys might not have as good with attention to detail, but that was from a company that uses pebbletec exclusively.
    Also, we wanted to upgrade from an inline chlorinator to a SWG system. We got a quote for $2000 - specifically, it includes an intellichlor salt cell with salt and wiring of unit. Does that sound about right? Is there a better SWG system I should be looking into?
    Finally, I don't know how i'll ever decide what color finish to go with. I can barely choose a wall color, so picking a pool finish is going to be impossible
    One of the pool builders recommended going darker to help heat the pool (we only have an electric heat pump now) - has anyone done that before? We are worried about darker finishes b/c our pool only gets sunlight from 9am to 4pm, but if it works, I'll go for it.
    Thanks - love TFP
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    38,254
    Re: Pool resurfacing / SWG upgrade
    The Pentair SWG has a negative that it is limited to 20% increments when not used with automation system. There are workarounds, but I would look at the Hayward. Equipment will be under $1000 and installation is fairly straight forward if you have and electrical and PVC experience.
    You are looking at under $100 in solar salt.
