Thread: Heliotrope 4000d
    Apr 2016
    Mount laurel
    1
    Heliotrope 4000d
    I have 240 coming from the pump timer, however when I connect the black and white to the 3 and 5 post as instructed the fuse blows. Any ideas?
    Jul 2015
    Central Valley CA
    1,109
    Re: Heliotrope 4000d
    240 is usually black/black or black/red are you saying your pump is wired using white as the second hot and not a neutral? Do you have a volt meter to confirm 240V across black/white?
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
