Thread: Anyone ever use the Aqua Quik Manual Vacuum?
    Has anyone ever used the Aqua Quick Manual Pool Vacuum? If so, do they like it?
    http://www.ocppoolsupply.com/Aqua-Quik- ... p/4800.htm
    My hope is to use it in my 18X36 IG vinyl pool for picking up algae spots missed by my dolphin robot. I don't have the remote type of dolphin robot, so if it misses a couple of 3 foot sections I may have to run it 2 or 3 times before it gets it all. And it often misses in the shallow end.
    I know I can use a regular pool vac, but I have a DE filter and algae clogs it up quick! So I was hoping this might do the trick.
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Anyone ever use the Aqua Quik Manual Vacuum?
    Those things are moderately useful in a hot tub, useless in a pool. You'd be better off with a brush for the algae and a leaf eater for larger debris.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The handle on that is only about 4ft, which might be an issue. Brush it and let the filter get it.
