Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 171
Thread: Newbie- bacaquil to TFP
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Unhappy Newbie- bacaquil to TFP
    I just started my pump up and started vacuuming leaves. Pool looks horrible! Nasty green! I was using bacaquil last year but refuse to pay for it anymore . I have just received my TF-100 testing kit and now I'm ready to begin!
    I tested but I am lost?
    Should I have wait to test?
    results from what I did is
    CL/.5
    PH/8.2 or above it was the brightest of red
    CYA/0
    help
    10,000 Gallon AG,Pentair Sand Filter,Built 2013, TF-100,No Restrictions
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Newbie- bacaquil to TFP
    Well this is a great time to start. You'll be sooooo happy when you see how much money you save and how great your pool is going to look! You'll need to lower that pH first, and then it is bleach time! Take pics- sometimes the colors are mind blowing when the bleach reacts with bacqua-goo. And be prepared for goo! One of our previous bacqua users should chime in here if you have more questions.
    Have you read this: Pool School - Convert Your Baqua Pool to Chlorine
    Jun 2014
    15,059
    Ah man, YS beat me to the post. Hello Progers, and welcome back. As YS mentioned, before you get to far into the new chemical levels for a chlorine pool, make sure you have read this page Pool School - Convert Your Baqua Pool to Chlorine and have done everything required to complete the conversion.
    Once that's assured, you basically have three priorities, lower that pH under 7.8, add stabilizer for a target of 30ppm, and increase chlorine to about 3 ppm on the first day, then increase to about 5 ppm after that (use regular bleach). After doing that, watch FC closely. If it disappears extremely fast or your water condition changes (clarity or color tint), let us know. But first make sure the bacaquil conversion was completed properly, then address those three things as soon as possible before you water warms-up. Let us know if you have any more questions.
    JoyfulNoise's Avatar
    May 2015
    13,193
    We can easily help you convert to a chlorine pool. Please read the links provided by the others. You'll want to make sure you fully digest and understand the process as it is laid out. Also, please note that Baqua-to-chlorine conversions can take A LOT of time (we had one last year that took 3 weeks to straighten out). So once you decided to do it, please make sure you are at a time in your schedule when you and any helpers you have, will be able to focus on it. This process can sometimes go quickly but many times takes at least a week or more. It's not something you can stop and start very easily so be ready to devote some time to it.
    With that said, it is very doable and we can walk you through it.
    Good luck,
    Matt
    Matt
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Thanks so much for all the info. I'm so excited to follow this pool method ! I have to go today and get the stabilizer to drop the ph. So I will keep everyone posted on my adventure!
    Jun 2014
    15,059
    Just to be clear for you .... muriatic acid will lower pH. Stabilizer is used to raise the CYA okay. Finally, have lots of bleach ready. Bleach is your friend at TFP.
    May 2015
    13,193
    Another comment. You DO NOT add any stabilizer until after the Baquacil is cleaned out. Adding stabilizer before you destroy the Baquacil will make the process impossible and you'll have to dump your pool water.
    Matt
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Ok so I need the muratic acid to lower the ph , right? Will add this before bleach ?
    Should I use the liquid or powder?
    Jun 2014
    15,059
    Yes, use the acid to adjust pH to 7.2-7.4 before you begin. Then follow everything listed on the link provided above in post # 2. Read it carefully and follow each step. Be patient, it will work. Liquid (muriatic acid) will work fine.
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Newbie
    my ph is 8.5 and I used the pool math to show me how much muratic acid in pool to bring it down. How long after adding the muratic acid to do the test again?
    this is great place to be when I need info!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Newbie
    Quote Originally Posted by Progers View Post
    If you make a lap around the pool with the brush after you add the acid, it should be mixed pretty good and you can test right then. You could always make a lap around the pool brushing, then rest your aching shoulders and drink a cold one, and then test pH again.
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    I got the muratic acid and I used pool math to get the right amount to put in pool. It was 8.5 when added. How long should I wait to do another test for the ph?
    May 2015
    13,193
    About 30mins. Be sure to brush the pool, it helps with the mixing and distribution.
    Matt
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Ok TNX , I'm on way out to check it again.
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Wow! That's amazing! It is 7.2! Now it's too low?
    May 2015
    13,193
    It's fine for a conversion process. Did you stock up on bleach? Did you read the Baqua conversion process?
    Matt
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Re: Newbie
    That's funny right there!
    i did check it and now it is 7.2
    now for the bleach , I start that in the morning! What fun, get to turn it funny colors and convert from that bacquil to chlorine
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: Newbie
    Oooo. Ooooo. Pictures please.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Progers's Avatar
    Mar 2016
    Lafitte,Louisiana
    93
    Re: Newbie
    Attachment 46641If u want to see here it is I have help coming to finish getting all those levels out! I have algae ! Should I slam before or after converting
  20. Back To Top    #20
    30,414
    Re: Newbie
    The conversion is a SLAM in and of itself. Read both procedures thoroughly but you will find them remarkably similar. The conversion article is the correct one to follow
