Thread: Pool Opening Question
    Sep 2013
    Bettendorf, IA
    31
    We are considering opening our inground pool tonight. Recently we had a bad storm and several sections of our fence were damaged leaving my backyard and pool open to anyone or anything. The fence company is coming this afternoon and will finish it up tomorrow, and I'd like to keep the mesh winter cover on the pool until the backyard is secure.
    Will it do any harm to get the systems going and water circulating now if I leave the winder cover on? I wouldn't think so, but wanted to ask.
    20x46 Rectangle IG Vinyl, Completion date mid-June 2014
    Depth 3'-3.5'-8', ~35,000 gallons, Hayward 310 Sand Filter, Hayward 1.5 hp single speed pump, ProLogic PS4 Automation w/ SWG
    Textured liner over corner stairs w/ 20' bench, 2 LED Lights, 2 Pentair Laminar Jets, Hayward Sharkvac and TF-100 Testkit
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Pool Opening Question
    No problem that I can see! Just make sure you remove any plugs etc from the skimmer, etc.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Make sure your water level is high enough.
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    I usually open my pool and leave the winter cover on. This keeps debris out as the water warms. Seems like the cover traps some heat in and helps a little to warm the temp. I take it off a day or so before we are ready to swim and install ladder and assist bar.
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
