Thread: Would you recommend pre-emptively changing the limiter on a brand new Aquarite?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    ...Or just waiting until /IF it cracked/burnt.
    Eg. are the replacement limiters from Digikey (570-1062-ND from Digikey.com) BETTER than what come factory installed on the Aquarite board?
    I've ordered two of the above just in case/to have on hand since this is a known problem with the Aquarite...but could actually have my electrician sauder it on/swap it out when he installs the unit if there was any reason to believe the replacements would fare better than original.
    Thanks in advance for your thoughts.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Would you recommend pre-emptively changing the limiter on a brand new Aquarite?
    I think they fixed the problem in their latest design by using a relay to by-pass the in-rush limiter when the cell voltage/current has stabilized. So you may not ever need those spares you bought. Ask user HaywardPool, he would know.
    Matt
    Sep 2013
    Charleston, SC
    540
    I just had to have both my board replaced on a 2 1/2 year old Aqua Rite and the local rep said they had made major improvements in this area. I would like to know if HaywardPool concurs.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    Jun 2011
    Long Beach, CA
    2,790
    Matt is correct, they have fixed this issue with the latest design, but I have no idea if you actually have the latest design. I would never replace the limiter without it going bad first. You would void any warranty if you did replace it, and if it does fail within three years Hayward should cover it under warranty.
    The new limiters are not a better build quality, the flaw is in the design of the board.
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    If it ain't broke...
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Thanks, guys, that helps a lot!
    Ping, its brand new, so hopefully this is the last thought I give to it
    Helpful Links:
