Thread: Air in leaf basket
    Mar 2016
    Crawfordville Florida
    11
    Air in leaf basket
    Recently installed an Intex sand filter on my 16 foot AGP. I had to use intex adapters that go from I believe 1 1/4 to 1 1/2 flex hose. I didn't use the cheap plastic hose clamps that came with the adapters, instead I switched them out for metal hose clamps. I seem to be getting what I think to be is to much air in the leaf basket on the pump. It is not enough air that the motor has started sucking air or lost prime, but every time I release the air, it always goes back to about the same point within an hour or 2. I've tightened every connection as much as I can, and all of rings are new and in place. Is it normal for that much air to be there? Or should it be completely free of air? Thanks in advance!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Air in leaf basket
    Welcome to the forum!
    How much air are you seeing? It shouldn't be much, and have you double checked the seal on the basket lid? It's common to suck air in there.
    Essential Links:
    Mar 2016
    11
    Quote Originally Posted by Patrick_B View Post
    The o ring on the lid is intact. I'd say probably about 1/4 of the total capacity of the basket fills with air... Enough to concern me, but not enough to expose the pump intake... Yet
    Mar 2016
    11
    Seems to possibly be the skimmer... I disconnected the skimmer for a few hours and didn't get any air at all... Is it possible that the turbulent water going into the skimmer sucks air down with it?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Quote Originally Posted by Jarrod421 View Post
    Very common. Low water level and high flow can create a vortex and suck air. It's easy enough to check, just look inside when it's running and look for a whirlpool.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Welcome to TFP, just raise your water a little, about 3/4 of the way on the skimmer
