Thread: How to run hot tub using existing pool heater
    May 2015
    Louisville, KY
    55
    Hello all,
    Our fiberglass pool was installed last May. We are still feeling the "sticker shock" of the cost of it. But I want a Hot tub! We have a perfect place for one. But there are two problems. After the pool cost, my wife and I are on somewhat of a "spending freeze" and we are no way, no how, going to buy a $8000 hot tub. The other problem, is that we most likely don't have enough power (amps) run to our pool shed, and I'm not going to have the electrician run more wire.
    The good news; my pool man says my filtration system, and my raypak gas pool heater, has the capability to run a hot tub, in conjunction with my pool (but might need an additional pump?). The heater has two settings on it, one for pool, one for Spa, but I have no idea how to set this up. In fact, when we were ordering the pool, they offered us one of those fiberglass pools that has the hot tub "built in", on one side of the pool. But the cost was going to be $10K more, and my pool man even told me it might be better and cheaper to just buy a real hot tub.
    My idea is to find a used hot tub on craigslist. There are literally dozens of them for sale, many under $1500. Then, I could retrofit the hot tub plumbing, to my existing filter / heater plumbing. If I can do this, it wouldn't require any new electrical permits, no additional load on electric panel (except maybe one water pump).
    Is this is dumb idea? Has this been done before? I can't seem to find any plumbing schematics showing how to plumb this. I want to do it myself, and not pay my pool man to do it. If I have him do it, it might not be done till 2020.
    Here is my equipment pictures below, showing my current heater, plumbing, etc.
    1. I have one main pool pump that runs the pool and fountains, and one booster pump that does nothing but run the pool robot cleaner thing.
    2. I have three drain lines form the pool: two bottom, one skimmer box
    3. I have two return lines to the pool, plus two small fountains.
    I'm pretty handy and feel confident I can do it myself, but I don't understand how the plumbing will look. How can the filter run both a hot tub and the pool at the same time, without mixing water? Or maybe it can't do it at the same time, but one at a time? I would be ok with heating only one at a time, but I think I would want water flowing on both, at the same time. Maybe that water flowing isn't "filtered" at the same time, but at least moving.
    I'm reaching out to you guys to see if anyone has done this before and maybe you know how to do it? I don't need any "hand holding". I'm just looking for your opinions if I should try it, and if so, do you have a basic schematic of how it is done with my current equipment?
    And these are the choices for hot tub location:
    Pool: 13,500 Gallon, San Juan StarDust Inground Fiberglass, installed May 2015
    Filter: Pentair cartridge filter, Clean and clear plus
    Main pump: Pentair Intelliflow | Booster pump: Pentair 3/4hp
    Pool Cleaner: Polaris 280 | Chlorine generator: AquaCal Autopilot Digital Nano Plus
    Filled pool with city water & using TF-100 test kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,470
    Re: How to run hot tub using existing pool heater
    Here is the basic Spa/Pool plumbing schematic. Seems to me what you want to do should work. Notice how when in the "pool" mode, the water is sucked from the pool through the filter and heater and back to the pool. When in the Spa mode the water is sucked form the spa and returned to the spa.
    38,262
    This is an interesting thought. So you would not be using the pump or heater or controller that are on board the hot tub?
    If you have enough access to the plumbing under the hot tub, you could certainly plumb in your pool equipment. Although I think I might prefer to use the onboard stuff myself. My wife wanted a hot tub and we got a used one for $300. It can run on a 120V circuit ... it is just plugged into an outlet on the patio. The downside is that on 120V it can either run the heater or the pump on high speed for the jets. Really not a big deal as we leave the temp set and when we get it turn on the jets and the heat does not drop too fast. Alternatively it could be wired in to 230V service so the heater and jets could work at the same time.
    Point is, you can likely find a hot tub that would work with your existing electrical without the hassle of trying to change all the plumbing and adding valves, etc, which does not look like it would be easy to do in your shed.
    May 2015
    Louisville, KY
    55
    Thanks Jim. that makes sense. As suspected, with one pump, I can only move water in the pool OR the hot tub, (one or the other).
    But this gives me some ideas on how I could do it.
    Thanks.
    Jason, I have heard of these hot tubs that "plug in" like you are saying. $300 is so cheap! I'll have to look into this. It would sure be simpler to do that. Running into the pool shed to change valves will be a pain, and likely, whoever does it will need an engineering degree to know how the exact steps to do it. Sure would be easier just to push a button.
