Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: lost in France
    Apr 2016
    France
    18
    Talking lost in France
    Hello all. Nice forum.
    Thought I would join you as I’ve problems and it would seem there is a pretty good chance of getting things resolved here.
    From browsing around I have got the message that reliable home test numbers are imperative. Would love to oblige…BUT I am in France and apart from dip testers and good old OTO not much else is available!
    The readings I’ve got below come from my pool shop (sorry) – from their Bayrol centifugal test machine . Even if acceptable it is not something I can do often. If we can use that for starters I’d be happy otherwise I’ve really not much else to go on!
    Readings are in mg/l.
    TAC 45
    pH 7.4
    FC 7.36
    CC 0.89
    TH 206
    Cu 0
    Fe 0.4
    CYA 75
    (Pool 40m3 (+/- 10k us gall.) IG concrete tiled with SWG, sand type filter filled with crushed glass media)
    Pool has been cloudy and has not responded to gentle cl addition. Slamming as I write with 70% cl granules with no stabilizer at 31 FC based on CYA of 75. (Added 1.3 kgs as per pool math). Water looking good (1st overnight). (SWG is functional but off, water limit too cold presently 16°C (60F) so everything is being done manually.)
    With a dip FC and an OTO tester, kitchen jugs and measures to dilute pool water any help to steer this thing ….or am I on my own?
    TAC at 45….any advice?
    Regarding CYA. During the summer the pool runs with SWG. The SWG is 2.5 times oversize – long story. Pool is 40m3 SWG designed for 100m3. Can I not run at lower CYA levels given there is a good amount of Cl produced to offset effect of sunshine? For and againsts?
    Also I have a tanning shelf (hollow box shape built in concrete, filled with light expanded clay beads fwiw) added non structurally to concrete shell. To avoid problems of water seepage, pressure difference, sealing etc the inside of the box is open to the pool via 2 small (1”) holes top and bottom. Water can enter and air can escape at leisure. The physics of this box arrangement are pretty straightforward, and seem to work. What is less clear to me is what is going on inside from the POV of water chemistry – is there a risk of some nasty contaminants creeping out into pool, as the stagnant water matures? Can I just block off the holes and leave it all for my kids to uncover in years to come ?
    Any comments much appreciated.
    Jun 2014
    15,255
    Re: lost in France
    Hello and welcome to TFP.. Good to hear you have been studying TFP processes and have a good understanding of what is required. At the same time, you are obviously limited with resources that would otherwise be readily available in the States (i.e. test kit). Just to be clear though on the numbers you posted above, I'm interpreting them as follows:
    TAC actually TA (Alkalinity)? If so, 45 it might be okay for now. Not much lower though.
    pH - 7.4 (good)
    FC -7 (Free Chlorine) - Based on your CYA of 75 (round-up to 80) it would be fine on a normal, daily basis. Actually might be slightly high when compared to our Chlorine/CYA Chart (link in my sig below). But if your water is cloudy, that indicates you may have an algae bloom starting, in which case you will need to perform a "SLAM" (link also below) to remove the algae. That requires a much higher FC level (31). That is something that would be extremely difficult for your to try and measure with any dilution method.
    CC (Combined Chlorine) The fact that this is over our .5 threshold confirms that your pool is struggling with excess organics and needs a "SLAM".
    TH 206 - I'm guessing this is your hardness (CH). A little low for a plaster pool, but easily raised later.
    CYA - 75 rounded-up to 80 is good for a SWG pool.
    Do you have access to liquid chlorine? That would be ideal to use during the SLAM. Also, is there any way you can order a TF-100 or Taylor K-2006C on-line and have it shipped? If not, perhaps just the FAS-DPD portion so that you can accurately measure the high FC levels required to perform the SLAM. MUCH better than any OTO tester. Oh, and as for the tanning shelf ... yes, I would be concerned about that. Algae can and will find its way into any hidden location. We see it inside ladder steps all the time.
    These are some items to help give you something to think about. Please let us know if you have any more questions and we'll try to help you from abroad. Great to have you with us.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: lost in France
    Morning Dipper - I have a concern about something you wrote:
    "Pool has been cloudy and has not responded to gentle cl addition. Slamming as I write with 70% cl granules with no stabilizer at 31 FC based on CYA of 75. (Added 1.3 kgs as per pool math)."
    What type of cl granules did you add?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2016
    France
    18
    Re: lost in France
    Wow! impressive response time.......
    @pabeader...the granules are called calcium hypochlorite at 70%. Contains no stabilizer. I've just thrown in the required amount by hand, dry, though on reading the tub it says mix with water first!?
    I plan on doing 48hrs at best guestimate slam level. Already at 24hrs it looks sparkling.
    @Texas Splash - thanks for your detailed reply. TAC is certainly alkalinity, and it would include carbonates and bicarbonates. Same as TA? Plan on raising TAC once slam is over (or should that have happened first?)
    I am looking at importing some kind of good test equipment. Have found in UK a Lamotte kit ref 2056 Colorq Pro which would appear OK, but your Taylor range is nowhere to be found.
    Kit or no kit, the info on this forum will allow me to aim for correct levels, whereas before I was well wide. Achieving them might be a challange.
    Any suggestions for holes in the tanning shelf - leave or block?
    TH is hardness at 206 I'm just over local recommendation of 150/200.
    newbuild 2015 IG rectangular concrete tiled. 40m3/10k gallon. I centre drain 2x skimmers. Oversize pump, pipes and filter - filled with glass media. Oversize SWG. Polaris bottom cleaner. Auto pH regulator.
    Test kit free....but not by choice.
    Jun 2014
    15,255
    Re: lost in France
    We're glad to assist wherever we can. Regarding the tanning shelf, I would suspect that as long as water is allowed to enter that area (shaded and without water circulation) it will be a haven for algae. You might be forced to close it off if possible. Since you are using Cal-Hypo to chlorinate, just remember it will increase your hardness (CH) substantially over time. At some point, if it gets too high, it could lead to scaling, so just be aware. You could raise TA slightly with regular baking soda if you have that available. This page Pool School - Recommended Pool Chemicals contains a listing of everything we advocate here at TFP, along with prescribed methods to add to the water. Of course you'll find a few links in our signatures valuable as well. If you can't get the entire kit, perhaps you can order just the FAS-DPD portion here at TFTestkits.net which will allow you to test the FC and CC as prescribed in the SLAM link below. I hope some of this helps.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: lost in France
    Welcome to TFP, there have been many people that have a hard time getting good test kits, here is the taylor K-2006-c that can ship worldwide from ebay
    TAYLOR K-2006C Swimming Pool/Spa Liquid Test Kit FAS-DPD Chlorine 2 oz Reagents | eBay
    Taylor K 2006C Swimming Pool Spa Liquid Test Kit Fas DPD Chlorine 2 oz Reagents | eBay
    Yes it is expensive (shipping is the worst part) but it works great and would help very much in your testing and taking care of your pool
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: lost in France
    As Texas has pointed out, your granular Cl is adding Calcium. All non-liquid Cl adds something. In your case it isn't CYA it's Calcium. Like Texas said, need to keep an eye on that. I would strongly suggest you switch to plain liquid bleach or liquid Chlorine. That way you aren't adding stuff you are going to have to drain water from your pool to remove.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: lost in France
    Welcome to TFP!
    If you do decide to raise your TA I wouldn't raise it above 60. If your PH is stable I would leave TA where it is.
    Apr 2016
    France
    18
    Re: lost in France
    @pooldv pH has always been pretty steady so I guess there is no need to raise TA.
    After 48 hrs of slam I reckoned my TC dropped overnight. (Evidence would be my dipstick for TC reading dropping - colour less purple!!!! The stick only reads to 10 max so I dilute my sample so that 30 (target TC) reads 10. It read 10 ish at beditme and less at breakfast, so I figured I had an overnight drop. Does FC need direct sun to burn or simply daylight?
    Slamming again today.
    Water is crystal - so even if my readings are bobbins is 3 days of slamming enough?
    As for liquid cl or bleach is that like household stuff?
    Are the stabilized cl bricks one can buy full of calcium too?
    Jun 2014
    15,255
    Re: lost in France
    Yes, the household bleach is fine as long as it is just regular (none of the scented or splashless stuff). On the bottle it will hopefully say "sodium hypochlorite" on the ingredients. The chlorine "tablets or pucks" not only have chlorine, but also have stabilizer which is responsible for raising your CYA too high. So that's why we caution people about using those too much. Here at TFP, we know a SLAM can take several days, so patience comes into play. Duration depends on how bad the pool was and where algae can be hiding (hence the tanning shelf). Diagnosis will be tough for you since you don't have the proper way to test FC and CC levels yet, but your effort is commendable.
    Apr 2016
    France
    18
    Re: lost in France
    Yep, household bleach here is sodium hypochlorite at 2.7%. it comes in 5l (1.3 USg) containers. Or u can get a more concentrated version 4.8% I think. On the pool math page do I put my % concentration in the field on the 1st line of FC box?
    Have found this tester.. Lamotte 2056 Colorq Pro 7 Digital Pool Water Test Kit: Amazon.co.uk: Garden Outdoors
    Is this the sort of thing?
    Jun 2014
    15,255
    Re: lost in France
    I don't have personal experience with the LaMotte kits. I like the links Casey provided above in post #6. But you are correct - simply enter the bleach percentage in that field on the calculator. The higher % you can get, the less you will need to apply each time. But the bleach you have available in your area may be limited, so you do the best you can.
    Apr 2016
    France
    18
    Re: lost in France
    Would be happy with Casey's kits on post 6.
    But shipping from the States takes a looooooooong time; waiting for the van to fill up at various regional depots.......unless you pay premium prices. The Lamotte kits come from UK and hence I will be up and running much sooner.
    Lamotte 2056 Colorq Pro 7 Digital Pool Water Test Kit: Amazon.co.uk: Garden Outdoors I think last link was a typo.
    Apr 2016
    France
    18
    Re: lost in France
    have just checked slam progress and pH is very pink. That's sort of 8ish.
    Does pH rise during slamming?
    Have hydrochloric acid (add or avoid) or pool shop pH reducer.
    again appreciate comments.
    My thanks to you
    Apr 2016
    France
    18
    Re: lost in France
    Took a look at TFP recommended products.
    Pool shop reducer is sulphuric acid (400g/kg)!
    Notice it doesn't appear on your list!
    What's best or least inconvenient to lower pH?
    Sep 2013
    Charleston, SC
    540
    Re: lost in France
    I did a quick search on here and found this link Test kits in the UK which lists a source in the UK for test. Good luck.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: lost in France
    Quote Originally Posted by morning dipper View Post
    During a slam your chlorine will be above 10ppm, anything ABOVE 10 will yield
    an inaccurate ph test, so wait till the slam is done and you are below
    10 for proper results.
    Dolphin E10 Cleaning Robot.
    Apr 2016
    France
    18
    Re: lost in France
    Quote Originally Posted by borjis View Post
    thanks - that's cleared that up.
    DFW, TX
    24,514
    Re: lost in France
    In the US we use muriatic acid, aka hydrochloric acid, most commonly. Sulfuric acid is also ok to use, but MA/HA is better if you can find it and a little safer and it doesn't add sulfates to your pool.
  20. Back To Top    #20
    38,524
    Re: lost in France
    Since no one directly responded to this ... we generally do not recommend the use of digital testers like the Color Q. They have limitations, require calibration, and you never know if they are just spitting out a random number. One limitation is that the FC only goes up to 10ppm.
