Thread: Blue Cloudy water
    Apr 2016
    wellborn, florida
    1
    Blue Cloudy water
    .6FC
    .4CC
    7.3 PH
    120 TA
    35 CYA
    80 CH
    Pool is blue, but looks as if someone poured milk into it. Used it all last summer, with no problems. Over the winter, it got quite a bunch of leaves and debris in it. I have gotten all the leaves out, but can't seem to get the really small particles out. Wondering If I should drain it. Or if there is a way to filter better. I have been running filter 24/7. The filter and the SWG are brand new, and not for sure which direction to go. Any help/direction would be greatly appreciated.
    16x48 Coleman, Vinyl, Above ground pool approx 6000 gallons, with an intex model SF60110 6amp 9275 LPH (2450 GPH), and Intex SWG model cs8110, Taylor2006 testing Kit
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Re: Blue Cloudy water
    With the FC level that low and cloudy water, it would appear you have an algae bloom. Fortunately you have a low CYA, so no dump necessary. You should be able to beat it in a few days by doing a SLAM. Read this article carefully and let us know if you have any questions: Pool School - SLAM - Shock Level And Maintain
    You should also lower your TA and raise your PH a bit, but the algae is the priority right now.
    Further reading:
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Aug 2014
    Northern IL
    4,615
    Also, you can use a 10ml water sample for the FC/CC test and then multiply your drop count by 0.5. It will save on reagents.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Did you use the Taylor 2006 test kit? .6 FC and .4 cc doesn't sound right. Did you use the 10 ml test and multiple X .5?...redo those t St and repost the results.
    Quote Originally Posted by MarianParoo View Post
    Lol sorryMarion, we musta been typing at same time...
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Nice work everyone!
