Thread: Kreepy Krauly Trouble
    Out of ideas and need some help please. I have a Pentair Kreepy Krauly pool cleaner, that is the one with the boost pump. It is about 3 years old and worked great until now. It just keeps making right turns and stays in the deep end of the pool. What I have tried thus far is to make sure it is getting plenty of pressure from the boost pump, moved the little pressure outlet at the back of the unit from right to left and back again, and switched the front and back wheels. Nothing I have done is of any help. It just keeps making right turns and stays in the deep end of the pool. If anyone has any ideas what I might try, I would be very grateful.
    1. Pool size 22,000 gal.
    2. Sand
    3. IG
    4. Vinyl
    5. 1 Hp Pump 75 gal per minute
    6. Saltwater
    7. Pool Pilot Digital Chlorine Generator
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Re: Kreepy Krauly Trouble
    I've never owned one - but I had a cleaner do turns and it was a wheel (flap thing) that was stuck- no idea how yours works but thought I'd throw it out there. (I know you said you changed the wheels)
    Also I must be hungry, when I first saw your post I thought it said Krispy Kream
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
