Results 1 to 7 of 7
Thread: Sand in the sediment window
    Sep 2014
    Rosenberg, TX
    3
    Just wondering if the sediment window is suppose to have sand in it? Mine has about 1/2 - 3/4 full of sand.
    On the intex sand filter install video, it appears to have no sand inside of it.
    MimiGin's Avatar
    Jul 2015
    Whitesboro, TX
    17
    Re: Sand in the sediment window
    Run it through a rinse till the bulb clears. Then turn back to filter.
    Intex - Round, Above Ground, Vinyl - 22'X52" / 10475 gal. Full sun 95% of day. Sand Filter w/ SWG.
    Sep 2014
    Rosenberg, TX
    3
    So, there should not be any sand in the sediment window? It seems like it would take a long time to rinse all the sand out of the sediment window. What causes sand to build up in the window?
    Jul 2014
    Oakbank, Canada
    389
    It acts like a tell tale gauge of sorts to let you know when you rinsed out the filter properly. The sand builds up in there when you back flush as a sign of cleaning, so you rinse until it is clear.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's not unusual for a little sand, even a tiny bit of filter sand to settle out there on backwashing. You want the water to be clear and clean in the sight glass to indicate you got a good backwash. If you're that full something isn't right. Do you mean it's half full of pool filter sand, or dirt that gets in your pool? If it's all filter sand, you may have over-filled the filter. Just a guess without more info.
    Essential Links:
    Mar 2016
    Crawfordville Florida
    11
    I recently installed an Intex sand filter and have the same problem. On the first backwash a huge amount of sand flooded the site glass. I back washed for a while and have back washed once more since then, without it clearing the glass of the sand. My guess is the large amount of loose sand that got flung around during initial back wash. This evening I plan on removing the site glass and emptying the sand from it, and I don't expect toto have that large amount on the next backwash.
    May 2015
    Hull
    3
    I to have an intex sand filter. Sand builds up in my sight glass also. In mine, it is less than a teaspoon though, just barely enough to notice anything. On mine, even after a good rinse cycle its still there. To me its not much to worry about. And unless you have your backwash port hooked up to pvc and you can't see the water coming out, I don't even know why there is a sight glass there? I like looking at the water coming out the end of the hose, not a tiny little bubble of a sight glass.
