Thread: D.E. and an AGP, where to add it?
    Apr 2013
    Eatonton Georgia
    145
    I went and got some D.E. this morning and want to add it to my pool. Everyone always says to add it to the skimmer. My sand filter and pump has a basket down at the pump and sand tank. Should I add it to the skimmer up at the top of the pool or would it be better to add it down at the pump basket?
    18ft. diameter, 48 inch deep Sharkline Reprieve AGP, 7000 gallons, Intex 14 inch sand filter with 3/4 H.P. 2,150 GPH pump, Intex SWG
    TF-100 test kit
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: D.E. and an AGP, where to add it?
    Pre-mix the DE with water and slowly add it to the skimmer. You only want to add enough DE to raise the filter pressure by 1 PSI.
    Here is a tutorial that you should read:
    Pool School - Add DE to a Sand Filter
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
