Results 1 to 7 of 7
Thread: The line from my filter to my chlorinator dips below the ground.
    Apr 2016
    Orlando
    3
    The line from my filter to my chlorinator dips below the ground. The bottom of this dip appears to go down to the water line of the pool. Would you know of the reason/benefit for this? Below is a picture of this line.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,542
    Re: The line from my filter to my chlorinator dips below the ground.
    Looks like a p-trap. Not sure why you'd need this. Maybe it's due to some plumbing code in your area.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Vibration mitigation? Strange, P-trap wouldn't work well without a vent and I don't see a drain on the bottom for winterizing (oh nevermind - Florida). Maybe the plumber was paid by the fitting, ha. More likely, JeffChap is right and its and unusual local code.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Interesting, but what would be the purpose I wonder?
    Essential Links:
    Oct 2015
    Katy/Texas
    411
    Typically, traps like that are used on sewer/waste line to provide a liquid seal to prevent sewer gas from entering the building. Look under your sink and you will see an example.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    JoyfulNoise's Avatar
    May 2015
    13,227
    Do you have a check valve between the pump and the filter?
    If the bend below ground goes below your water line, then water will only drain back to the level of the water line in this bend. This will keep the pump primed with water. A simple check valve between the pump and filter would do the same thing.
    Matt
    Oct 2015
    Katy/Texas
    411
    A siphon break.
