Thread: mixing different bleach strengths?
    JayG's Avatar
    Aug 2015
    Harrison, NY
    204
    Hi,
    I asked this question in my "bulk bleach storage" post, but I remembered that new questions are best asked in a new thread. So, my question is whether if I already have 12.5% in a tank, can one safely add 8.25% as long as one adjusts the dosing for the resulting combined dose? Not something I would plan to do, but if I already had one type and couldn't find the same strength, is there any harm in mixing? My gut says "no", but I thought I'd check.
    Many Thanks,
    Jay
    Jay--Metro NYC
    35K gal, in-ground, free-form, pebble finish, 2 skimmers, 3 returns, autofill. No spa, no features. Partial shade.
    Pentair C&C cartridge filter (400 sq in), Pentair VS pump, Pentair 140 btu heat pump, Triton Plus Robo-cleaner; Stenner with 55 gal bleach cistern. TFT 100 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: mixing different bleach strengths?
    No, mixing 8 bleach and 12 bleach will only dilute the mix.
    Essential Links:
    JoyfulNoise's Avatar
    May 2015
    13,247
    No harm/no foul! You're all good.
    Matt
    JayG's Avatar
    Aug 2015
    Harrison, NY
    204
    Thanks for the quick replies. Sometimes one's gut response is on point, but other times (like mixing tri-chlor and cal-hypo) are less obvious.
    Good to know.
    Jay
    Jay--Metro NYC
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's a very prudent question to ask anytime you're mixing chemicals. Better to ask than have a problem.
    Essential Links:
