Thread: DE Filter Air Bleeder keeps getting a hole knocked in it
    I have a Pentair 60inch FNS Plus DE filter, and this is the 2nd time this has happened. How is this happening? I turn the pressure valve when I start the pump to let the air out. Any ideas?
    Seems like part of my pool startup procedure now is to buy a new one of these when I clean the grids.
    30,000 gallon in-ground vinyl liner
    Hayward Sand Filter, Hayward 1.5 Hp pump, SWG (brand TBD)
    Complete renovation summer 2013
    Marlboro, New Jersey
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: DE Filter Air Bleeder keeps getting a hole knocked in it
    Welcome to TFP
    Are you opening the air bleeder after the pump is started? I have not heard of of one blowing out, so after you close it, it stays open? are you doing the same as this video
    Cleaning a Pentair Clean Clear CC50 - CC200 Filter - YouTube
    Hope this helps
