Thread: Too high of a pressure?
    crustfan's Avatar
    Jul 2012
    Palm Coast, FL
    35
    Running my system without the cartridge filter, the gauge reads 26psi. I bought a new gauge and it reads 22psi. With the filter in, its about 30 psi. Do I have a problem with high pressure? The gauge at the Caretaker in-floor system which is after the filter reads 10psi without the filter in. It reads 0 with the filter in. I think I need a new filter at least.
    Jerry
    30' x 15' ~ 15,000 gallon pool & spa, Diamond Brite, Hayward Aqua Logic PS-4, Turbo Cell T-Cell 15 SWG, EcoStar SP3400VSP pump , Star Clear Plus C17502 filter, Rheem P-M206A-EP-C heater, Caretaker 99 5-port 1.5 inch valve
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Too high of a pressure?
    I have been learning more about the in floor systems, they seem to have higher pressures than a pool without them.. how much really depends on how each is installed..
    Have you tried to clean your filters in a tsp soak?
    crustfan's Avatar
    Jul 2012
    Palm Coast, FL
    35
    Duh? The problem is that I have my variable speed pump turned up too high at 95%. If I lower the power to 50% I get around 10psi at the filter. However the psi of the Caretaker is 0psi and the power of the in-floor cleaning jets looks lower.
    Recently I had to replace part of the pump motor that burnt out. I wonder if I wore it out by running it too high and at too high a pressure all these years since 2012.
    What are the optimal settings for psi at filter and at Caretaker?
    I'm doing a TSP soak now.
    Jerry
    Jul 2015
    Gilbert,AZ.
    123
    there is a screen that sits on top of the caretaker valve, the 2 large unions have to be unscrewed and then the 90 degree pipe can be pulled away and a screen will sit on top of the valve, it is a domed rigid screen that has to be positioned with the screen pointing up, do not install the screen pointing down towards the valve like a bowl, as this will cause rapid accumulation of debris that impedes water flow to valve, this screen is commonly overlooked and when dirty causes valve pressure to be low, and filter pressure to be high, caretaker valves in general can confuse someone who sees high filter pressure as dirty filter, etc.
    check the screen regularly, you will be surprised what accumulates on it,and how often, the valve will need rebuilding from time to time also
    22,553
    Also for the caretaker system you won't be able to run the pump at low speeds and have the system function properly. The caretaker system runs in the 20+psi range at the filter to operate correctly.
