Thread: Gray or white conduit to light wet niche
    Apr 2016
    South East USA
    78
    Hi,
    Does it matter whether gray (electrical) PVC conduit or white PVC conduit is used from a junction box to a wet niche?
    Also can gray and white be solvent-welded together?
    Both are schedule 40, but I bought gray thinking it was for electrical, but forgetting the conduit can fill with water and wondering whether to return for white.
    Also the stub from the existing wet niche is white pvc... can I weld gray to that stub?
    Just hoping y'all can save me yet another trip to Lowes
    ft.
    PS. In case anyone is wondering I will use a 8 AWG ground/bond wire from the jb to the lug in the niche.
    ~22,000 gallons, freeform, Pebbletec, beach entry AquaRite SWCG v1.33 Hayward Tristar SP325EE pump for main draw & skimmer Hayward sand filter S310S 1.5 hp booster pump Paramount PCC2000 in-floor cleaner, skimmer, debris containment canister Waterfall Pentair Intellibrite 5g LED light in Pentair stainless wet niche Jandy Lite2 heater: removed Auto-fill: deactivated
    30,403
    Re: Gray or white conduit to light wet niche
    Generally, grey is used for electrical work. As you probably know, it is a TON cheaper than sched 40 PVC but I am not sure why. I'll bet we have some electricians/plumbers that can tell us why.
    I see no reason they cannot be glued together but I have never tried it.
    Apr 2013
    Sacramento, CA
    2,769
    The grey should be used. It will have printed on the outside "UL listed." It should be at least 3/4" 1" would be better and worth going back to Lowes for an exchange.
    BONDING WIRE NEVER GOES IN CONDUIT. NEVER EVER NOT EVER. The correct wiring for a pool light is shown in this thread:
    Relamping - use long light cable instead of junction box
    A green insulated ground wire goes from a ground to the niche, with the connection covered in putty, to the junction box.
    Apr 2016
    South East USA
    78
    Quote Originally Posted by gwegan View Post
    Ok, thanks, yes, I have that lined up... insulated 8AWG wire potted to the lug in the niche.
    What I find confusing is that Mike Holt seems to refer often to "grounding (bonding)", for example:
    (b) The equipment grounding (bonding) conductor can terminate at the grounding terminal of a listed pool transformer that meets the requirements of 680.23(A)(2).
    Apr 2013
    Sacramento, CA
    2,769
    That must be an old edition -- that is confusing. PM me with your email and I will send you the current 2014 edition of Mike Holt.
    Gordon
