Results 1 to 18 of 18
Thread: Automatic Pool Cover with vinyl into the channel instead of webbing
    Jun 2010
    Kansas
    20
    Has anyone seen a cover where the vinyl goes all the way into the channel and around the rope instead of webbing? CoverCare is telling me that's the way their covers are built, but I can't find anything similar on the net.
    Webbing seems to be the chronic problem on my covers.
    Thoughts?
    Aug 2014
    Northern IL
    4,615
    Re: Automatic Pool Cover with vinyl into the channel instead of webbing
    I am not sure what you're asking. Could you try again or post a picture?
    Haven't heard of the vinyl going into the tracks. I wouldn't think that it would have good wear characteristics. I also wouldn't think that it would glide easily enough.
    Ask them to send you a sample for inspection.
    Note: Automatic covers are usually mostly vinyl except on the sides where a different material is used to go around the ropes and inside the tracks.
    Support the site
    Jun 2010
    Kansas
    20
    Quote Originally Posted by JamesW View Post
    That's what I was thinking also. I've never seen a sample that included the rope. I'll call them to see if they can bring one over.
    Dec 2015
    Lehi, UT
    25
    The vinyl for an company should not go around und the rope. This company has a relatively new website and I can't see any manufacturer affiliation. They may be making their own and doing it wrong. Hard to tell without a picture
    Jun 2010
    Kansas
    20
    Attachment 46709
    Thoughts on this? Looks like normal webbing to me.
    Jun 2010
    Kansas
    20
    Any thoughts on who might me making this cover? It looks different than the PCS covers I've had in the past.
    Looks like webbing not vinyl.
    Support the site
    Jun 2010
    Kansas
    20
    The pictures certainly answer that very clearly. I'm baffled that a sales guy would say they run vinyl in that channel. Maybe a misunderstood him.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Coverstar makes a cover with the vinyl around the rope but it costs more. I bought an off brand "Automatic Pool Cover Inc." replacement which was about a $1000 cheaper and thought that was what I was getting. It turns out as actually meshed webbing again which was what failed on our last Coverstar cover. We actually had the Coverstar cover restitched once before the cover was too old to repair again. So far we have not had any issues with our replacement cover going on three years.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Dec 2015
    Lehi, UT
    25
    I am looking into who is using the grey rope right now. I know that this is webbing sewn onto vinyl. It looks like PCS to me.
    I know that PCS is improving a lot of their processes since they were bought out by Coverstar and moved over to that facility. So there are some visual changes being made to the PCS products.
    The only cover that Coverstar makes with vinyl around the rope on the sides is a manual snap down cover.
    You can get the vinyl caught in the track if the guide feed on the end is loose. I have seen this happen and it looks like the vinyl is going straight into the track and covering the rope.
    Jun 2010
    Kansas
    20
    Quote Originally Posted by Honey Badger View Post
    Thanks!
    I'm pretty sure that no manufacturer would use vinyl around the ropes that go into the tracks. If anyone has pictures or written descriptions from manufacturers that indicate otherwise, please post the pictures or a link to the manufacturer's information.
    Support the site
    wjr75's Avatar
    Jun 2013
    IL
    836
    I don't think it may be "vinyl" but they don't use the stitching that always seems to fail. They use some sort of a heat seal around the rope. This is from Coverstar Central.
    Patented heat-sealed webbing
    which is a substantial improvement over
    industry standard sewn webbing and pro
    vides significantly longer webbing life and
    improved cover operation.
    Jun 2010
    Kansas
    20
    Quote Originally Posted by wjr75 View Post
    Good info on an alternative cover. Thanks!
    Jun 2010
    Kansas
    20
    I think I have it pinned down -- cover is made by Automatic Pool Covers in IN. 18 oz vinyl cover with "vinyl" webbing, 1/4" woven nylon rope with Kevlar core. Does anyone have thoughts or experience with this cover manufacturer or choice of materials?
    Jun 2010
    Kansas
    20
    Does anyone have experience with Automatic Pool Covers out of Indiana?
    Dec 2015
    Lehi, UT
    25
    Was it shipped out of Indiana, there is a Coverstar/PCS facility there. Coverstar Central also has an office there. The picture you sent was not heat sealed webbing.
    It looks like it might be Aquamatic Pool Covers
