Results 1 to 7 of 7
Thread: Automation: intercepting data from Acu-Rite wireless sensors
    robstar's Avatar
    Apr 2015
    Mountain View, CA
    48
    Hi! I have an AcuRite 00617 floating wireless thermometer. It works (though the floater leaks and could use some add'l sealing) but i'd like to capture the data for computer monitoring/analysis/control.
    I'm able to read a signal off the 3.3V data pin on the receiver unit, but i'm having trouble decoding it. AcuRite is not interested in helping, but i'm sure we can do it.
    If anyone else is interested, let's chat.
    ~15kgal IG plaster, hayward cartridge filter, old-ish pool, TF-100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,100
    Re: Automation: intercepting data from Acu-Rite wireless sensors
    I've done something very similar with a very similar data stream.
    The diagram for the RF-211 is just showing you that the period of the signal is constant and that the positive pulse width is what determines the value of the bit. I've seen this kind of encoding before.
    Often there are unused bits in the stream, and if you can flush out the unchanging bits early on you can concentrate on figuring out the ones that do change.
    Have you thought about using a variable power supply and changing it to see if you can identify the bits that carry battery status?
    If you have the hardware, I've had much more success working the problem from the other direction. Now that you know the format of the data word, using a sound card or I/O card to modulate an RF source and sending test words to the receiver may let you progress faster. You can change bits and see the response (or lack thereof) on the display immediately. I wrote code to allow me to change the bits and send the data, and had much better success than trying to just figure the encoding out.
    robstar's Avatar
    Apr 2015
    Mountain View, CA
    48
    Quote Originally Posted by JohnT View Post
    Great ideas! Will try!
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    No input on your issue but I've had 3 of those over the past few years. When they work they're great but I find the lifespan to be maybe 6 months. I've seen other brands on amazon. Anyone have any comments/recommendations on other brand wireless thermometers?
    21,000 gallons
    Pentair 420 Clean & Clear Plus Cartridge Filter - Filter Area: 420 - Design Flow: 150
    Inground Plaster
    Pentair Whisper Flo Pump - 1 HP - Model CCP420
    Pentair MiniMax NT Series Pool Heater
    Aqua Rite Electronic Chlorine Generator
    Polaris 280 Cleaning System
    robstar's Avatar
    Apr 2015
    Mountain View, CA
    48
    I'm not making progress on this, so in the meantime, i've made my own sensor. (Adafruit HUZZAH (ESP8266) + LM35 + 4xAA)
    robstar's Avatar
    Apr 2015
    Mountain View, CA
    48
    robstar's Avatar
    Apr 2015
    Mountain View, CA
    48
    Thread update! I put together an Arduino library, in case anyone's into that sort of thing: GitHub - robstarling/ArduRight: ArduRight Arduino library -- let me know if it works for you! It has an example and everything.
    Referencing the picture in What encoding is used in this signal? - Electrical Engineering Stack Exchange , you'll need to solder wires to the "SH", "D", and "G" pins. To run the example sketch, connect those wires to pins 2, 7, and GND, respectively. I wouldn't worry too much about the dire "3.3V vs 5V warnings in the .h file -- it's working fine for me with a 5V Arduino.
