Thread: Pump Died, 3 days for replacement
    kfpool's Avatar
    Jan 2016
    Port Orange, FL
    131
    My pump died last night (Monday) & I ordered a replacement motor that is supposed to arrive Wednesday. Worst case scenario is that I will not get the motor replaced until Thursday evening. Are there any precautions I need to take during the 2-3 days without filtration or circulation. My water has been in perfect balance needing 18 oz of bleach per day. If I continue to add bleach at that rate & brush a little to stir things up I think I should be fine; however, I would like some advice.
    Thanks in advance for the help
    Port Orange Florida
    In Ground Plaster Kidney
    36 x 18 - 16,000 Gallons. 3ft - 6ft
    Hayward C12002 Cartridge Filter, 1-1/2 HP Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Pump Died, 3 days for replacement
    Sounds like a plan. Except brush a lot, so you really get the bleach to all corners of the pool.
