Results 1 to 7 of 7
Thread: Porcelain tile
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Porcelain tile
    Has anyone tried using porcelain tile to cover their ODK? Is this even a viable option given the potential weather conditions and stress? would hate to have cracked tiles everywhere.
    https://www.flooranddecor.com/porcel...+40in.&start=2
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Sep 2013
    Charleston, SC
    537
    Re: Porcelain tile
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    30,419
    Re: Porcelain tile
    What's ODK?
    Sep 2013
    Charleston, SC
    537
    Re: Porcelain tile
    Outdoor Kitchen.
    30,419
    Re: Porcelain tile
    You can certainly use tile as a finished surface on a "countertop".
    A 1/4" layer of "cement board" should be used between the tile and the framing of the kitchen.
    Porcelain tile is maybe the best tile to use because it is close to water proof and, installed properly, the freeze-thaw cycle will have no affect.
    Sep 2015
    sacramento
    7
    Re: Porcelain tile
    What do you mean by "cover"? If it's the countertop you're referring to, then yes. I used 1/2" cement board under my counter top, thinset, and then tile. If by "cover" you're talking about the sides of the base, I suppose you could do that too, but it will cost a lot more and much more labor than if you just used Dryvit to finish the base sides.
    Jul 2015
    Long Island City, NY
    70
    Re: Porcelain tile
    Absolutely. Used often for garage floors in high end automobile service shops in the Northeast where it is subject to daily freeze-thaw cycles. If you have significant temperature swings (greater than 20 degs/day) then a crack isolation membrane is advised.
